Pontiac GTO 2004-2006 The Modern Goat
reducing wieght on the gto
Old 04-03-2008, 06:01 PM
Kamauxx's Avatar
I don't know if it's already been mentioned but I took my two magnaflow mufflers off yesterday and realized they weigh probably about 40lbs EACH!
I don't know what kind of muffs you got but if they aren't bullet type I would bet that they weigh a ton!
On the flip side I ordered to replacement mufflers that are being shipped by UPS and by their calculations the total weight is 11 lbs WITH packing/shipping supples, so I figure 4.5-5 lbs per muffler.
In short, if you want to take off 60-70 lbs, spend 100 bucks and get light weight aftermarket mufflers.
Old 04-04-2008, 05:45 PM
Johnnyb4439's Avatar
Heres a good start...
All these things I just weighed (bathroom scale, +/- 1.5 lbs):
Skid plate: 18 lbs.
(BMR Skid Plate: 5 lbs)
Back seats (both pieces): 45 lbs.
Front Passenger seat (with bracket): 65 lbs.
Fuel Tank Brace: 25 lbs.
Fuel tank brakets/bolts(both): 12lbs(thanks PitchBlackGTO)
V-Brace for towing: 15 lbs.
Strut brace: 3lbs(thanks ls1jeeper)
Spare/jack/everything in trunk: ~50lbs
Front Floor mats: 4lbs total
Rear floor mats: 2.5lbs total
Rear Muffler heat shielding: 5lbs
Stock spoiler: 5lbs
Stock battery: 6 lbs heavier than a red top
Stock airbox/filter: 4.5lbs(thanks chris442)
Stock Exhaust manifolds: 28-31lbs
Stock driveshaft: 27lbs
(trans yoke, 2-piece shaft, rubber donuts, all bolts)
Difftechnics driveshaft: 17lbs
Stock 04 midpipes w/ cats: ??lbs
Stock 05-06 midpipes w/ cats: 50lbs(thanks chris442)
Exhaust after mids until mufflers: 23lbs(thanks ls1jeeper)
Stock 05-06 mufflers: 56lbs(thanks ls1jeeper)
Stock 17" wheels/tires: 52lbs each.
Stock 18" wheel/tires: 54lbs each. (thanks 87LC2)
19x9.5 TSW Thruxtons w/ 265/30's: 50 lbs.
19x8 TSW Thruxtons w/ 235/35's: 48lbs.
19x8 Niche Rhine wheel/tires 235/35: 51lbs
17x8 OZ Super's: 43 lbs.
Headers and catless exhaust - lots of weight saved(~30lbs)
Weight going to LT's is 15lbs saved
Weight going to shorties is 17lbs saved
Cats alone weigh around 15lbs I know since I just shipped them out the other day.
Anybody feel free to weigh items and post it here and I will edit in into this first spot.
Disclaimer: Any weight savings listed have nothing to do with safety. Anyone who removes a fuel tank brace knows why they are doing it.
Old 04-04-2008, 08:47 PM
damon_Z's Avatar
Really good info there, Johnny. Thanks.
Old 04-05-2008, 11:45 AM
Hey, no problem.
Old 04-08-2008, 05:47 AM
EPP
EPP's Avatar
This battery is in use in one '05 GTO that I know of, without any problems. It is much lighter than an Optima.
http://www.exoticperformanceplus.com....html?item=834 Bob
Old 04-24-2008, 08:05 PM
Floridaman's Avatar
How about the glove compartment cover.
Old 04-29-2008, 01:06 PM
surfinjoe's Avatar
I just weighed my stock exhaust vs. the magnaflow system. The result is an 18 lb. weight savings if you have a magnaflow system on a 2004 GTO. Not sure about the 2005 or 2006 systems.
Quick Reply: reducing wieght on the gto
