Rear End Sag Need Help!
hey anyoen knwo of whwere i can get an air bag drop in for my rear springs top prevent my *** end sagging when i launch my gto?? or better yet... rubber spring spacer or the air bag kit (only woudl be used at the track,,., no daily driving)
If you're on stock springs, that's the problem. The OEM springs sag after a few thousand miles. The only remedy is new springs.
Save 250 bucks and some pedders zero drop or 5/16 raise and your problem will be solved.
You could also add a set of drag bags. It will lift that *** up and give you a little something extra at the track. I have some on my other car and they got that *** up nice and perky!
Drag bags can be found here:
http://www.bmrfabrication.com/index.php
However, I agree with Kamauxx, get a pair of Pedders zero drop springs and do it right.
http://wretchedmotorsports.com/produ...c4628578568c18
Why are drag bags redneck? They solve two issues: sagging springs and wheel hop. Many cars and trucks come with air ride suspension from the factory. Am I missing something? That's all drag bags really are!
If you go the new spring route, it sounds like you will need the drag bags anyways.
Did I mention that I am a redneck! :-)
I just replaced the system in my Ford (bad word I know) and it is identical to my firends drag bags that we installed last week. Now I am not saying that they serve the same purpose as drag bags, but they are the same thing from what I can tell.
If i put zero drops on my gto i have a 6spd and like u all know they like to axel hop. will those springs make it worse? I am looking for a problem fix cause i have 19" rims and when i get on it the fenders cut my side walls cause it suck down so bad.
Drag bags are a better option as 1. you don't have to ride around looking like your car is going to off road all the time 2. they better control wheel hop. I put in drag bags and keep them deflated except for when I track it. Get AirLift bags for the Mazda MPV and you can install them without cutting the bump stops off like they instruct with the "correct" bags. Cheaper too. I got Lovells 20mm drop springs which not only make the car look better but also DD ride well and improve handling by lowering the center of gravity.
