Project Comments & Discussion Use this forum to discuss Sponsor projects.
Katech's C6 Vette Build
Old 07-05-2007, 11:11 PM
6techniques's Avatar
Default Katech's C6 Vette Build
https://ls1tech.com/forums/sponsor-vehicle-projects-shop-tours/743878-jason-s-katech-street-attack-z06.html
Wow, that looks really well put together!
Do you have anymore exterior shots?
Old 07-05-2007, 11:13 PM
And how much power are you looking to make with it?
And is this a full track car or will it see street duty as well?
Old 07-06-2007, 11:10 AM
LS1TECH Sponsor
Katech_Jason's Avatar
Originally Posted by 6techniques
https://ls1tech.com/forums/showthread.php?t=743878
It was raining so I don't have more of it lowered. Here it was before mods:
Old 07-06-2007, 11:12 AM
LS1TECH Sponsor
It made 609hp/569tq on the engine dyno. It is a street car that will see some road course a little drag racing.
Old 07-06-2007, 02:24 PM
soulless's Avatar
Car looks great man! Could you give a little more detail about the Motul set up? Their website was pretty generic. How much of an improvement in ride and handling?
Old 07-06-2007, 03:17 PM
Stang's Bane's Avatar
Incredible Jason!! You are really going all out, aren't ya??
I heard you recently got one from Minnesota to work on, any truth to that??
Old 07-06-2007, 03:27 PM
WILWAXU's Avatar
Bitch'n car!
Old 07-06-2007, 09:09 PM
Fulton 1's Avatar
Looks badass, Jason. Nice work.
Old 07-07-2007, 03:05 PM
LS1TECH Sponsor
Thats Moton. It is an incredible improvement over the already amazing Z06's factory handling. It feels like it is on rails. Ride quality does not diminish.
Old 07-07-2007, 03:06 PM
LS1TECH Sponsor
We recently built an engine for a customer whose installer is in Minnesota.
Old 07-07-2007, 04:03 PM
soulless's Avatar
You mean those aren't cans of brake fluid, damn typo. I was wanting to know how the system works and whats all invloved with installing it.
Old 07-08-2007, 11:46 AM
LS1TECH Sponsor
They are 7-way double adjustable coilovers. There are 7 positions of compression and rebound dampening. The canisters are nitrogen charged so you can adjust the pressure on the shock fluid. The spring perches are threaded on the shock body for ride height adjustment. Installing it is pretty easy. They take the place of the stock shocks. Two holes are drilled in the body to pass the fluid lines to the canisters which are mounted in the trunk area. Front canisters are mounted on the radiator upper cover. There is quite a bit of setup time to adjust the ride height. I have initial settings completed, but I still have to get the car on the scales and corner balance it.
Old 07-08-2007, 11:14 PM
67maro's Avatar
Thats one sick car so its yours? Those are some sick numbers nice work.
Old 07-09-2007, 04:01 PM
patriotformula's Avatar
whoa... that looks serious man.
Old 07-15-2007, 07:18 PM
LS1TECH Sponsor
Thanks. Yes, its mine.
Quick Reply: Katech's C6 Vette Build
