MS4 Cam, Patriot Gold Extreme Springs, Retainers etc
I have a Texas Speed MS4 (Magic Stick 4) that I used for less than 500 miles, Patriot gold extreme springs, titanium retainers, Super 7 locks, .080 hardened pushrods 7.400" length and ARP crank bolt for sale. The ARP bolt is brand new never used. I put this cam in my Magnuson supercharged car and then had a problem with the engine that stayed in the combustion area of cyl#1. I changed engines and superchargers and chose a cam from the supercharger vendor. The cam comes in the original box along with the cam card. You will need new valve seals as I would never reuse valve seals or recommend anyone do so. I have a used set of lifters that have 12kmiles on them from my Z06 motor. They never ticked and all rollers roll smoothly. I also have a Comp Cams hex adjust timing set that I ran for 12kmi.
Here is a quote from Texas Speed
" Magic Stick V.4 239/242, .649"/.609" Camshaft 111 LSA The Magic Stick V4 camshaft is Texas Speed's premier LS1 camshaft!
The MS4 camshaft is the result of extensive engine dyno testing & research! Engine dyno results have shown over 80 horsepower gains with no other changes on a stock 2001 LS1 engine!!
2300-6800 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle! Custom tuning and PRC dual valve spring kit required
This camshaft typically gains approximately 60+rwhp!"
I have sold a handful of items here and on corvetteforum under the same user name. I accept Paypal.
call, PM or email me for any Q's
Cam kit cost me 775.00 shipped with ARP bolt plus tax.
500.00 shipped obo for the cam kit and I'll throw in the lifters which are in excellent shape if you want them. I just built a new motor and didn't want to reuse the lifters. Comp Cams timing Hex-adjust timing set that I put 12kmi on. Paid 169.95. Yours for 75.00
Bret Bradbury
cell# 972-741-7457
Bret Bradbury
cell# 972-741-7457
Thanks Kizzle.
Just want to let everyone know that I can't access LS1tech from work, so all PM's will be answered when I get home from work. Feel free to call my cell.
Also, the spring seats are included. The only thing not included that came with the kit is the valve seals.
