just got my LS1 for my subaru WRX
#61
yeah we moved it down till the oil pan is clearing the member , and its almost level with the hoodline.. the firewall is gonna need a bit of clearancing but nothing big...
#63
Originally Posted by redmist
The primary weight reduction comes from the loss of the 4 wheel drive.
Originally Posted by LS1_boostdscoob
werd... i was contemplating the STI rear diff with maybe even a quaiffe...theres stock ones running like 600 hp on them so they should be able to take some abuse with a quaiffe
The standard R-160 diff in a WRX is not at all strong ( I believe sone Nissan/Datsuns also use an R-160, which refers to crownwheel diamater in mm )
The latest STI uses an R-180 diff, which is stronger, as are its driveshafts etc.
an R-180 rear end will bolt straight in, but buy complete with shafts and hubs etc.
Tallest rear end ratio is a UK/Euro/US spec STI which has a 3.54 rear end.
Jap specs will have a 3.9, as they use a different transfer box.
#64
Originally Posted by smokinHawk
there you are, i figured youd be on here.
and i told you those are 97-98 heads
https://ls1tech.com/forums/showthrea...ht=casting+806
not ls6 aka z06 heads
it looks like you have the zo6 intake manafold. as there is no EGR present.
plus you have a 98 style water pump.
since your adding boost id try to get some 6.0L heads bigger CC will alow for more boost.
All of this just to beat a turbo mustang
But perhaps that is not even an LS6 intake and just a plain jane 97-98 Corvette intake. The C5's had a EGR less LS1 intake.
Personally with the 97-98 heads and that intake, I think you got just a plain jane 97-98 LS! out of a vette. Not a Z06 motor. Pull the heads off and take a few pics of thise for us.
#66
i need some sponsors... trying to finish this.. i will put your name as big as you want on my car.. just a little help would be appreciated... goin for first subaru in the 8's... help me make it true and i might just make you famous... and more $$$...
#68
LOL, dont we all. you should not start a project like this if you do not have the $$$ to finish it. I would say the chance of you getting a large sponsor is 0%. what do they have to gian by giving you $$$$? you have a one off car that they will not build conversion parts for. the car manufacture sure wont give you $$$ (they would kick you in the nuts though). just slow down a little and finish the project a little slower. it will be an awesome car!!
#75
thanks guys really..
i just got a guy from a fab shop whos interested in helping so i should have some pretty slickshit motor and tranny mounts.. hopefully he'll help with the 9" setup...
#76
if you need help with the turbo piping let me know.
#79
Remember to correct for bumpsteer. Moving that rack will add another component to the conversion equation.
An R230 300zxtt/Q45 diff is nearly a 9" ring gear and is very very stout. Putting a solid rear end out back.... . Why not keep it IRS and put some upgraded 300M axles along with it? IRS cars can 60 foot awesome as well.
Maybe you should create a mid engine LS1 powered Brat with C5 transaxle instead. You could have 2 turbos mounted on a roll bar like the original KC Daylighters!
