Parting out 2000 Trans Am
Category: Drivetrain
Price: $100
Location (State): KS
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
LS1 short block with one stripped head bolt hole, ran great but found metal shavings in oil. Had an odd ticking noise but not rod knock. - 350. -$450 if I have the local GM dealer fix the head bolt thread.
Ported 853 Heads. $200
Stock 4l80e- Works perfect. Has a quiet whine in first gear only. I've read this is normal due to straight cut gears but not sure. -$450
BMR 4l80e crossmember w/ torque arm mount- Basically brand new with a brand new torque arm bushing. - $220
Aluminum driveshaft w/ new U-joints and 32 spline slip yoke for the 4l80e installed. NEEDS BALANCED. $150
RevMax 3800 stall 4l80e torque converter. Works great with less than 1000 miles on it. $450
Flat 6 bolt flexplate w/ spacer- $50
Stainless 1 3/4" headers for ls1 fbody. I've painted them black and I've had to dent them a bit to fit. $100
True dual exhaust all the way to the back with 3.5" tips. 3" pipe from the headers to the axle, then reduced to 2.5", over axle then full sized mufflers. Made by an exhaust shop with pretty decent quality, and sounds awesome! Doesn't even hang lower than an aftermarket y pipe. $450. I'll have to cut it to get it out of the car.
Edelbrock Victor Jr. EFI intake manifold with black painted fuel rails, black painted ultra low profile elbow, all braided fuel lines and fittings needed to connect directly to stock fuel line. Crap ebay throttle body comes with it free of charge lol. The intake is also ported. $500
42lb Injectors- $90
SLP lid - $50
2000 Maple red metallic Trans am roller with black painted ws6 17" wheels, aftermarket ws6 hood. Interior is okay. Needs some body work but looks good from 20-30 feet away. $1200 obo? Not sure what it's worth.
Sale pending on transmission, stall, headers, injectors, and slp lid. Yes I do have coils and brackets. Injectors are stock injectors from 3.8 s/c. I modified the harness and used the stock computer to control the 4l80e. Contact Slow67 on here for that info
