***396 LT1 short block - Brand new, high end build!***
Category: Accessories
Price: $2
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): PA
Item Condition: Brand New
Engine: LT1/LT4
LS Engine?: Non-LS Part
Specifications:
-Seasoned GM LT1 block:
-Hot tanked
-Howards billet splayed main caps and ARP main studs installed
-Align honed
-Bored to 4.030"
-Torque plate honed
-Stroker clearanced
-Square & zero decked
-Rotating assembly balanced
-Eagle 3.875 stroke 4340 forged crankshaft, internal balance
-Eagle 5.850 H beam rods, bushed with floating pins
-CP Pistons custom piston set with CP wrist pins and spiral locks, 9cc dish with valve reliefs
-Total seal plasma moly file fit ring set
-Durabond CHP performance camshaft bearings
-Clevite H series main bearings
-Clevite H series rod bearings
-Clevite brass freeze plug set
-Professionally assembled
With a 54cc cylinder head and .039 head gasket, the compression ratio would come out to around 12.3:1.
For compression ratio purposes:
Bore: 4.030"
Stroke: 3.875"
Piston to deck: Zero
Piston valve relief/dish: 9cc
Short block comes exactly as pictured. It is just a short block. Cost to duplicate $5,700.
$3,500
