2002 camaro SS roller
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $11000
Mileage: 55000
Location (State): MS
Color: Orange
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
It runs 6.50s at around 102 and weights about 3500 with me in it. I don't know the horsepower its never been on a dyno, it was street tuned on e85. It has a clean title but has a previous salvage title because of theft. The bad is the motor is out because of thrust bearing failure, it happened last summer and I haven't had the time to fix it and I've just lost interested in it. I will try to get pics up tomorrow. Any body interested in it can text me. 662 660 6548 Jeremy mod list: seasoned lq4 block, callies compstar crank and rods, wiseco pistons -2 cc, arp main studs, comp cam 248 254 621 621 114, adjustable timing set, ported trick flow 220 heads with 59.5 cc chambers which makes the compression about 12.8, yella terra rockers, trick flow pushrods, ls7 lifters, fast 102, ptm 102 throttle body. The trans is a th400 with reverse manual valve body, trans break, neal chance converter. The rear end is a moser 12 bolt with 35 spline axles, full spool and no abs, wolfe anti roll bar, bmr adjustable lower control arms, adjustable pan hard bar, umi tunnel mount torque arm, boxed sub frame connectors can't remember the name, 3 way adjustable shocks, bmr cross member
i know theres a lot more stuff on it thats all i can't think of the top of my head
and questions just text or pm me thanks.
this is a decent deal even with the title and motor issue. it should easily part out for $13k+ (even if only valuing the stock roller with a 10 bolt for $2000, but if it's as clean as it looks with 55k miles, it's likely worth more depending on the interior). I say keep it, rebuild the mtor and ask $15k or part it out and get your money out of it! If nothing else though, GLWS!
