KILLER 2002 Turbo Z28 Part out!!! Forged 370"/4L80/9" FS or Trade!!
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
2002 Z28 camaro, 77,000 miles, clean title. Car was assembled by Bobby parks (Black Nasty) shop in Md. Motor and trans has less then 1500 street miles, car is a solid street car. Makes 700/750tq on pump gas. Will make close to 1000hp on race gas. Or add A Meth kit and turn it up on pump.
4102181620 call or txt
Cara located in York PA, can ship but pick up or meeting is much preferred on large items
****Will trade for other street or race cars. Possibly trucks, also looking for a forged LS1/LS3/LS7 NA/Nitrous short or long block for my vette, nitrous goodies, will also take a built rear or Tranny for C5 or TR6060/C6Z rear as always. Cash is king.***
Car runs/drives perfect. Can be street driven for miles on end, has great oil pressure and dosnt get hot or over heat at all even on these 100deg days . Have multiple videos I posted to YouTube of the car, links at the bottom
Motor -$4500 long block,$5500 with intake/TB and fuel rails/sensors/accessories
.030 over 2004 LQ4 block
Weisco turbo pistons
Callie's H beam Rods
ARP main studs
ARP head studs
ARP2000 rod bolts
Stock polished crank
ASP under drive balancer
ARP Crank bolt
Balanced rotating assembly
LS7 lifters
.080 7.400 chromoly push rods
Custom ERS 112 turbo can
LS9 head gaskets
Billet timing chain set
Ported LS6 oil pump
Ported 317 heads with .660 PAC springs and titanium hardware
Stainless valves
Edelbrock pro flow port matched intake
Rev extreme 90mm billet throttle body
Lingenfelter 2 step/timing box $190
UMI billet motor mounts $100
2002 PCM and Engine harness $350
Griffen sheet metal radiator $350 with fans and fan controller
Turbo kit: SOLDDDD
Flipped truck manifolds
Custom hot side (can keep AC)
T78 Turbo (new)
44mmTurbo smart BOV
Synapse 60mm waste gate
4" front mount IC
4" stainless bumper dumper down pipe
Fuel
255 walboro prinary and a 340 aeromotive secondary intank pumps
80lb injectors
Edelbrock billet rails
8an feed line
Aeromotive boost reference regulator
Trans SOLDDDD for whole swap in this list
Rebuilt 4L80E with electric lock up on a switch
Upgraded clutches,bands,steels
Manual valve body
Huge front mount trans coolerSOLD
AN lines SOLD
B&M pro ratchet shifter SOLD
Precision vigilante Billet converter 3600rpm set up for boost SOLD
TCI sfi flex plate SOLD
Tubular cross member SOLD
Urethane Tranny mount SOLD
Locar dip stick SOLD
Drive shaft shop chromoly 1200hp shaft for 4L80E to 9" SOLD
New u joints
Rear SOLDDDD for complete rear end, no brakes
Moser 9" rear end
Drop brackets for LC Arms
Moser aluminum center section
TruTrack posi
Moser 31 spline axles
3 channel Abs
4.10 gears
18x10.5 18x9 Z6Z style wheels for Fbody, rear tires are about shot Fronta are great wheels are in excellent condition $600 price drop $500!
Suspension
CTSV front calipers $400 with rotors and pads
C6Z front cross drilled rotors
New drilled and slotted rear rotors Soldddd
Braided brake lines
UMI Tubular upper/lower control arms SOLDDD for all 4
UMI Tubular K member $400 PRICE DROP $300!!!
UMI Tubular rear control arms SOLDDD
UMI Tubular pan hard bar $100
UMI Body mount torque tube SOLDDD
Edelbrock front coil over shocks and springs SOLDDD
Edelbrock rear shocks SOLDDD
Weld in sub frame connectors to lower control arm mounts
Battle boxes welded in lower control arm mounts
Exterior/interior
Sunoco 3" cowl hood SOLDDD
6LE carbon fiber targa top (removeable) not perfect SOLDDD
6LE carbon roof bow
6LE power race seats $400
Whistler HID headlights SOLDD
LT tail lights SOLDD
AEM Eugo Wideband/water/boost gauges on pillar $300 for all gauges and pod
4 point harness $50
Grant quick release wheel with bolt on hub $100
Empty shell with bumpers and doors,hatch and most of the interior and body harness with Clean 75k mile title $1000
