2000 corvette ls3 twin turbo
Year: 2018
Make: Chevrolet
Model: Corvette
Price: $25000
Mileage: 116638
Location (State): TN
Color: Beige
Transmission: Manual
Drivetrain: Rear Wheel Drive
-6 speed
-116k miles
Engine:
-LS3 FORGED shortblock
-King Cam bearings
-24x reluctor
-LS2 crank
-Katech C5R timing chain
-Martin Smallwood Cam Motion 8620 core, 227/243 .621/.611 117lsa
-Morel 5315 lifters
-LS3 heads, cut .003 port work in bowl area
-Tick Performance .660 dual springs with titanium retainers
-Comp cams Hi-Tech 5/16 pushrods
-Comp rocker trunion upgrade
-cometic gaskets
-ARP head studs
-Ported oil pump
-LS3 intake manifold
-LS2 throttle body
-Fluidyne balancer
-plasma moly rings
Fuel:
-Bosch ID1000 injectors
-LPE 255 in-tank fuel pump
-Bosch 044 secondary inline fuel pump on Hobbs switch
-Racetronix secondary fuel pump wiring kit
Forced Induction:
-TTiX twin turbo kit
-57mm turbos
-Mounts directly next to the engine block
-Eboost2 boost controller
Accessories:
-DeWitts cut-down radiator
-Mechman Billet Industries Alternator 170a
-Catch can box, with fittings to both valve covers
-Red powdercoated valve covers
-2.5 bar map, speed density tune
-Snow Performance Stage 2 methanol kit (uses windshield washer tank)
-Optima battery relocated in trunk
Drivetrain:
-McLeod RXT twin disk clutch
-poly solid driveshaft couplers
-tick adjustable master for clutch
-Steel flywheel
-Stock T56 and Diff (3.42)
Interior:
-9/10
-Pillar pod with AEM wideband, AEM FP, Eboost2
-MGW shifter and ****
-Insulated cargo divider (cuts down on noise a lot)
-Bluetooth radio
-HUD (needs to be fixed, it works but aims too low on windshield)
Misc:
-18% tint
-C6Z Spyder (replicas) 18/19"
-Nitto NT05R drag radials on rear
-RE11 front tires
-HALO modified LED taillights
made 800hp/800tq on a mustang dyno, on conservative 16 pounds of boost and 16 degrees of timing car has less than 30 miles on it since engine and drive line has been built turbo setup has about 800 miles on it
car is in middle TN
$28,000
