Aes 390ci forced induction block and tvs2300
Category: Engine - Complete Motors
Price: $5000
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NJ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Engine specs-
Brand new gm 6.0 block
Callie's dragonslayer forged crank
Callie's compstar forged rods
Diamond forged pistons
Steel top ring set
Arp main and head studs
Arp rod bolts
Trick flow 220cc heads
Trick flow 7.4 pushrods
Yella terra roller rockers
Comp dual valve springs
Ls9 head gaskets
Ls7 lifters
Ls2 timing set
Btr stage 3 PD blower cam
Arp cam retainer bolts
Ls2 timing cover
9.7-1 compression
Supercharger specs
Brand new magnuson tvs2300
Rear overdrive cog drive
2.8" front pulley
80 lb Siemens Deka injectors
Looking for $5000 for the complete long block and $5000 for the complete supercharger setup
Call or text Mike at 201-428-4671
I have a complete aes390 block for sale, less than 2000 miles on it... Moving onto different project. Also for sale, tvs2300 supercharger with less than 500 miles on it for f-body/gto accessories. Supercharger was in an s10, so some small items will need to be purchased to make a complete kit.
Engine specs-
Steel top ring set
Arp rod bolts
Ls9 head gaskets
Ls7 lifters
Ls2 timing set
Ls2 timing cover
9.7-1 compression
Supercharger specs
2.8" front pulley
Engine specs-
Steel top ring set
Arp rod bolts
Ls9 head gaskets
Ls7 lifters
Ls2 timing set
Ls2 timing cover
9.7-1 compression
Supercharger specs
2.8" front pulley
