New water pump, tires, injectors, lid, heads, valvetrain, free stuff, make offers!
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): VA
Item Condition: Used
LS Engine?: Fits LS Engine
$40 Magnaflow high flow cat 2.5" in/out "heavy metal" version 99006HM low mileage but has rust around heat shield, pipe and element are good
$65 LS1 853 heads from '99 with LS6 springs. Ready for a freshen up but were running great when pulled.
$10 SS center caps for C6 Z06 style wheels from OEWheelsllc.com
$5 Rocker arm bolts for both sides
$5 used head bolts, no good for mounting but good for mock up or whatever.
$5 Stock oil pan baffle, F body
$5 Coolant cap and dipstick, brand new
$5 LS1 valley cover
$15 Stock clutch master cylinder with drill mod
$5 stock pressure plate bolts, 6
$5 (4) truck fuel injector plugs only
$20 '99 LS1 cam, great shape
FREE STUFF - But need a few bucks for shipping!
-LS7 MAF plug
-Clutch slave shim, I think it is 1/4"
-Oil pickup O-ring FelPro red, I think it is for truck style, not sure.
-PCV hard line and rubber fittings from LS6 - NO PCV BOOT!
-O-ring that came with new slave.
*valvetrain parts are high mileage but look good*
-timing chain, very little slack
-oil pump
-lifter trays
sold Brand new LS1/F Body waterpump from Autozone with gaskets. Never mounted.
sold each set of four truck fuel injectors, 4 are P/N 25317628 and 4 are P/N 25323974 All came on the same intake so I don't know if they are compatible or not.
sold MTI lid, cracked around neck, wrapped in duct tape and it ran fine but it is old.
sold Continental DWS tire - 275-40-17 about half tread, still shows "D W S"
sold SLP underdrive pulley. Great shape, used bolt for mounting but need a new one (TTY), no belts
sold LED headlight bulbs 9006 low beams, work in stock housing.
Sold -Pushrods, all rolled straight on glass, lifters
sold LS1 flywheel, stock, needs resurfacing but good. Also have PP and disc if needed for mockup.
sold Complete LS1 F Body intake manifold, fuel injectors, rails, EGR plug, MAP sensor(retaining tab broke but zip tie holds it in fine) great shape just .
sold LS6 coolant blockoffs, rear only
sold Stock LS1 Balancer and low mile belts, main and a/c.
sold 2 piece Corvette batwing oil pan from 03 Z06 with windage and pickup, level sensor, temp sensor, low mileage, very clean.
sold Stock LS1 MAF, untouched, good screen.
sold Fel Pro valve cover gaskets, perimeter bolt, brand new, bought the wrong ones.
sold Motive universal bleeder, only used a few times
sold PCV tubing between valve covers
