F-body Accessories - 4L80 - SC&C Control Arms - LS1 T56 Harness - Spec 3+ Clutch Kit
Price: $1
Location (State): NC
Item Condition: Used
LS Engine?: Fits LS Engine
Complete LS1 F-body accessories with all brackets / bolts and belts - $475
2002 LS1 shortblock with Comp cam and F-body oil pan - $800
LS3 fuel rail - $90 shipped
6 rib RIP 3.0" pulley for TVS1900 / TVS2300 - $50 shipped
CSR carbon fiber shield for TH400 - $100
Complete 4L80 transmission - newer 2005 7-bolt case - $550
LS Coil Packs w/ brackets - $85
LS valve covers w/ new Felpro seals/gaskets - $50
LS rockers, pushrods and pedestals - $50
10-1/2" aluminum GM flywheel for 1-pc rear main seal SBC - $75
New SC&C SPC adjustable upper control arms with pro-lite adjusters and shim plates for 68-72 Nova or 67-69 Camaro - $300
Brand new Turbonetics boost controller # 10402-50 - $70
Also have a couple F-body PCV lines and a couple other sets of injectors....LS3 factory takeoffs, dyno-only 42lb FIC flowmatched injectors bought from TSP.
336.339.6867
Thanks-
Rick
^^^ I do not know exact miles on the motor. No issues when pulled just going a different route. Cam grind is 3727R / 3728R on a 112+2 (.598/.601 - 234/240). Sounds choppy but nothing too radical. Motor made real good power for a smaller lift cam.
^^ I do not know which port job it is or cc. Could call LPE with that serial number and they should be able to give you that info. I can try and give them a call early next week.
^ Yes, FAST intake is complete as pictured with the rail.
^^ Not looking to sell fuel rail only unless everything else sells first and buyer doesnt want the rail.
^Still have a few people somewhat interested in the whole setup. Really just want to sell it all complete but if nobody pans out then I'll let you know.
