BNIB: Wiseco Pistons 3.800 bore
Category: Accessories
Price: $550
Location (State): NY
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Got a brand new set of wiseco pistons in the box.
Part # K474M965
3.800 bore -2.2cc
Can text for a quick response 518-578-3636.
$550 shipped
I called and Unfortunately, that set, is per each piston. Those are basically for refreshing a motor.
Also those are not correct for the piston set you have listed. Those are specific to LJMS Wiseco pistons that are made exclusively for him. His spec pistons come with 1.0mm, 1.2mm, 2.8mm, XX steel nitride top/napier second rings and upgraded Tool Steel .200" wall S718 pins.
The K474M965 Pistons shown calls for 3805HF rings which are a different size.
3805HF = WISECO 3.805" BORE, 1/16"/1/16"/3mm RING SET
I found this spec info below regarding the pistons shown in your ad on another site.
Part #: K474M965
Notes: 2618 Alloy Forged Pistons
Fits 3.622 Stroke
Set of 8 Pistons
Recommended RingSet: 3805HF
Rings Sold Separate
Includes Pins: S643
Must use w/ K1 Rod
I believe you are looking at these: WISECO 96.5mm, 3.800" BORE, 1.0 / 1.2 / 2.8mm RING SET 9650XX
Part #: K474M965
Fits 3.622 Stroke
Set of 8 Pistons
Rings Sold Separate
Includes Pins: S643
Must use w/ K1 Rod
Part #: K474M965
Fits 3.622 Stroke
Set of 8 Pistons
Rings Sold Separate
Includes Pins: S643
Must use w/ K1 Rod
Either way for the price these are you would still be ahead than buying them brand new then buying rings.
