1994 Cobra Kaase Headed 521 BBF Grudge Car
Year: 1994
Make: Ford
Model: Mustang
Price: $17500
Mileage: 14100
Location (State): IL
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Engine:
~74 Block .030
~CHP Dominator Rotating Assembly Internal Balanced
http://www.coasthigh.com/Ford-521-Fl...92-dm-f521.htm
Top End :
~Jon Kaase P-51 Cylinder Heads Ported
~Harland Sharp 1.6 RRs
~Jomar Rocker Stud Girdle
Cam:
~Comp .738 lift .301/.304 112 solid roller
~Comp Solid Roller Lifters
~PAC valve springs approx 300 lbs closed 1100sh open.
Exhaust:
~Hooker 2" primary 3.5" collector LTs (Needs bigger)
~Custom 3.5" X pipe
~3.5" Dynomax bullets with turn downs
Trans:
~PA Super Comp C4 with Brake http://www.performanceautomatic.com/...nsmission.html
~Ultimate 9.5" Custom Converter for setup
~Oversize Trans cooler
~Hurst Quarter Stick
~Custom reinforced steel driveshaft
Rear End:
~Narrowed 1" per side 8.8
~Moser Spool
~35 spline Moser axles with 9" ends
~3.27 FMS gear
Rear Suspension:
~UPR Double adjustable lowers
~Edelbrock Double adjustable uppers
Front Suspension:
~QA1 K member
~Front Coil Overs
~Strange 10 way shocks
Brakes:
~Aerospace Front Brake System
~Wilwood Rear Brake System
Fuel:
~Quick Fuel Pump
~-8 Feed into Quick Fuel Regulater
~Holley HP 4500 Flange 1050 Dominator
Power Adder:
~Edelbrock 300 horse Nitrous Plate Kit with -6 Feed system
Cooling:
~Be Cool BBF extra capacity radiator
~Moroso BBF electric water pump
Charging:
~JPC one wire modified 3g alternator
~Moroso NHRA electrical shutoff system
I am sure there are a million things I forgot lol. Best to text me or call and talk about it. Ask for Ben at 309 791 2617
Looking for $17,500 cash OBO or will consider trades of:
Nicely modded 99-02 F-bodies
Nicely modded 96-2001 Cobras
Stock or modded 2003-04 Cobras
Or GM or Dodge Diesel trucks 2002 or newer
