1999 Trans Am M6 w/ LS6 Heads/228 Cam/ and much more!! (VIDEO)
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $10700
Mileage: 17000
Location (State): TX
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
Asking Price: $11,700 NEW PRICE: $10,700 OBO
If you have any questions call/text me 956-373-6095
Car will not come w/ these wheels, they will come w/ C5 Deep Dish wheels & tires I will post those pictures of the wheels later today. It has cold ac, heater works, rear defroster works, power mirrors, power driver seat, stock radio w/ aux input, all the seats are in good condition, dashboard is cracked, all the gauges work, it has a code for I believe to be the DRL (daytime running lamp), cruise control works, vfn ws9 outlaw ram air hood, reverse camera, led reverse lights, clean looking tail lights (no cracks, they are different from the pictures here), and fog lights work. Car has current inspection & registration. I got receipts for everything that was installed new.
Engine has approximately 17k miles, Body has unknown miles, (last report was in 06 for 220k miles) someone before me swapped out the cluster. I just found that out today. I forgot to mention it has new brake pads all around, slp maf, and slp strut tower brace.
NEW INFO: I forgot also that I had installed NEW hatch shocks, NEW hood shocks, and NEW fan motors.
Machine work was done at salas in mercedes, tx
Assembly of cam bearings, crank, etc. by Eddie (monster motorsports) at 0 miles
I installed everything else @ 15,000 miles, the list..
Tuned by Noe at Aggressive
Engine:
228/228 Comp Cam .588/.588 lift (1500 miles when installed)
799 heads (fresh resurface)
Pac .600 Springs (1500 miles when installed)
LS6 intake
#28 Injectors
LS7 lifters (new)
7.4 TSP pushrods (1500 miles when installed)
LS6 ported oil pump & shimmed (1500 miles when installed)
SLP Double Roller Timing Chain (new)
SLP Lid & induction kit
LT Headers
Engine Mounts (new)
ARP Head Bolts (new)
Victor Reinz Full Engine Gasket Kit (new)
Alternator (new)
Bosch Iridium Spark Plugs (new)
MSD Spark Plug Wires (new)
Oil Pressure Sending Unit (new)
OPSU Relocation Kit w/ Mechanical Gauge (new)
BWD TPS (New)
Knock Sensors w/ Harness (new)
Transmission:
T-56
MGW short throw shifter
LS7 clutch kit (new)
oem slave cylinder (new)
Tick Performance Master Cylinder (new)
Tick Performance Speed Bleeder (new)
Differential:
4.10 Gears
Royal Purple Fluid 75w-90 (new)
Suspension:
Bilstein Shocks & Springs (new)
Monroe Strut Mounting Kit (new)
I am about 5 1/2 hrs away, and i'm actually going this weekend hopefully to the south portion of houston. let me know if you have any other questions call/text me 956-373-6095.
