1971 Ford/Mercury Capri LSX Turbo
Year: 1971
Make: Mercury
Model: Capri
Price: $10500
Mileage: 176000
Location (State): MD
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Chassis
-1971 Mk1 Ford/Mercury Capri
-177K Miles
-10PT Welded Roll Cage
-Square tube stiffened chassis
-2550 lbs
Engine
-5.3L LS Iron Block
-Head Studs
-Flipped Manifolds for turbo setup
-Borg Warner S400 T6 75mm Turbocharger
-HP Tuners, 15 psi
-Speed Density
-Custom Grind ISKY Camshaft
-2 Precision 39mm waste gates W/ dumps
-4" Fender exit exhaust
-Turbo Inlet in front high beam location
-Large FMIC in front grille
-AEM TruBoost
-AEM Wideband
-Bosch 044 Fuel Pump
-Stainless braided fuel lines from cell to engine
-Aeromotive FPR
-Aluminum Radiator
-High Flow Electric Cooling Fan
Drive train
-4L80 W/ Transgo HD Shift Kit
-External Transmission Cooler W/ Electric Fan
-Yank PY3400 Converter (rated to 1200whp)
-Winters Sidewinder Shifter
-Explorer 8.8 Rear, 31 Spline, 3.08 LSD
Interior
-Recently refinished, fully stripped and painted
-Kirkey Aluminum Racing Seats W/ Covers
-Factory Dash W/ Boost and AFR Gauges
-OBD Dash Gauge setup for CLT, IAT, RPM, MPH and other readings
-Trunk Mounted Fuel Cell
Body
-Paint is not fantastic, but works as a 20 footer
-Some slight rust here and there but nothing serious
Braking System
-SN95 Mustang front disc brakes
-Explorer rear disc brakes
-Manual brakes, vehicle stops well
Suspension
-SN95 Front Coilovers W/ Camber adjustment plates
-QA1 rear coilovers
-3-Link Rear Suspension
Wheels/Tires
-Front: 15" trailer wheels w/195 street tires
-Rear: 15" steel wheel W/ 225 Mickey Thompson ET Street (Needs more tire)
Price: 13,000 OBO
Please contact me if you would like to come view the car.
-John
It definitely moves along nicely. No personal track times with it, i've only used it for street cruising. The PO left a couple low 11 slips in the car, likely on the 225 ET streets. A better/bigger tire setup should easily put this deep into the 10's.
-John
-John
