Complete Turbo kit, ATI balancer, Scanmaster
Old Oct 23, 2008 | 11:48 PM
Websy21's Avatar
Default Complete Turbo kit, ATI balancer, Scanmaster
Time to update my thread since I've sold the majority of my items.
SOLDComplete PTK turbo system with allot of upgrades, this is not an ebay kit like some are selling on this board this is a real PTK kit. All tubing is coated and wrapped so you dont have too. Only 500 miles on system, something came up and need the cash to pay off all this stuff. It includes allot of extra stuff as listed:
*All hot parts all mandrel bent, coated by jethot, and wrapped with DEI wrap professionally wrap alone for system cost $350 for all of it extra wrap included as well
*T80GTS turbo by Jose at Forced inductions good for 1250 horsepower. Turbo is not loose in any way shape of form only used for 500 miles, only saw synthetic oil, no chipping of blades and spins very nicely. Started out as a T76GTS then was sent to Jose for upgrading to a better exhaust wheel and bigger 80mm s wheel.
*turbosmart 48mm wastegate with a inner 4psi and outer 10psi spring as well as a outer 7psi spring.
*Header type system will also include a set of new spark plug protector boots good too 2100 degrees continuous as well as a new set of Taylor race 409 wires with 1200 degree wire shielding.
*Turbo blanket and 3 velcro pipe sheilds as well
*It also comes with a new full air to water intercooler system brand new never used with large core, remote mount resevior, pump, new high pressure lines, intercooler piping, couplers, t-bolt clamps, and everything needed good for turbo systems running 25+ PSI and good too 1500hp. It costed $2100 for it. Look up A2W intercooler that MightyMouse is using if you are thinking twice about it. The biggest thing was that I didn't want to hack up my bumper and with this you don't. You can street drive with it and never have to add ice unless you want to at the track.
*Kit also comes with a Complete Crankcase/PCV system - I bought a brand new Husky oil seperator that is common on this forrum and believe it was close to 40 bucks. Also has a catch can, required hoses(fuel line which won't colapse like vaccum line), pcv valve, checkvalves, fittings, etc, etc that added up quickly. I compied Mightymouse's sytem with minor tweaks and he has a long thread to explain it all. It worked great anyways.
*4500 for just the basic system and have added over 2500 in extras such as turbosmart 48mm wastegate, wrapping, spark plug wires, sheilding, and protectors, threaded IAT sensor, oil feed and drain line and required fittings, bosche relays, alternator relocation bracket and belt, pcv system, etc, etc. Total invested is well over $7000 would like to get $4000 shipped for all willing to take the loss as I dont need this stuff around anymore. Shipping will be substantial with the nice big boxes I have. Exhaust runs up to where a Y-pipe connects, this is how I had it setup.
I just recently listed it on ebay and will end the auction for $4000 pending your location
To whomever buys the kit, I will email you some threads I've stickied for myself that I have spent countless hours reseaching and all the info I can help you get it on faster, etc. I can also email you some pictures I took of the install to aid you as well.
Thanks again and I still can't believe I am letting it go for this much I will reread everything today as this took me over 2 hours to do. I may have missed something but hopefully not, I think I got it all.
SOLD I got a very low milleage, stock diameter ATI Race dampner as well. Its stock diameter for both the assesories and A/C. $300 shipped. I also have a new ARP bolt & washer that I'll sell with it. This is among the best dampner and reccommended with a turbo system do to the heat and high horse power.
SOLD Lastly, I have a Scanmaster for an LS1. I am asking $200 shipped. All the info you need for it is here:
SOLDhttp://www.fullthrottlespeed.com/itemdesc~CartId~{EVEREST8A1FDB4E-A2D6-49F0-B31C-399E517727A8}~ic~050SCANLS1~eq~~Tp~.htm
They are great tools and I also have the entire stereo bezel for a camaro that enables it to snap right in and look like it belows there. So if you have a Camaro, pop yours off and put this one on. For the T/A guys like me I had it mounted with some sticky tack above the steering column. It looked great there and could still see everything in the factory cluster. Its in great shape and barely used. I like the option of clearing codes with it too, among reading multiple items.
I just took off a SLP driveshaft loop used for about 1000 miles. I will let it go for $90 shipped
Subthump Stealth sub box with Rockford HE2 10'' for drivers side $150 + shipping
Subthump stealth amp rack barely used $100 shipped
Rockford fosgate HE2 10'' subwoofer $90 shipped
I will sell the sub box separetly if someone wants to buy both 10'' subs. I am at work right now so I will get pictures up when I can.
I also have blackout tail light covers for a LS1 Trans am, make an offer since I am not sure what they are worth?
My trader rating speaks for itself so no worries in regards to buying from me. I love this site and wouldn't jepardize that.
I do prefer a pm if you want me to get back to you ASAP. I am busy but will check frequently as possible throughout the day!
- Mike
Old Oct 24, 2008 | 04:25 PM
Websy21's Avatar
Bump
Old Oct 26, 2008 | 02:51 PM
Websy21's Avatar
Bump
Old Oct 27, 2008 | 10:28 AM
Websy21's Avatar
All pm's returned to!
Old Oct 27, 2008 | 11:25 AM
dschmittie1's Avatar
pm sent
Old Oct 27, 2008 | 02:56 PM
Websy21's Avatar
All pm's replied to!
Old Oct 27, 2008 | 04:48 PM
payment sent on ATI balance
Old Oct 27, 2008 | 05:27 PM
Websy21's Avatar
Payment received, thanks again!
Old Oct 27, 2008 | 11:56 PM
jmill96Z's Avatar
Has this kit been on the dyno? What kind of power did it put down? Let's talk shipping to 99506
Old Oct 28, 2008 | 12:04 AM
jrocstar's Avatar
if you part it out pm me
Old Oct 28, 2008 | 06:54 PM
Websy21's Avatar
pm's replied to
scanmaster going once for $180.............
Old Oct 30, 2008 | 07:13 AM
Websy21's Avatar
Bump back up to the top, lots of interest on turbo kit! Auction ends on ebay tonight as well as a trade may also take part! Last chance!
Old Oct 31, 2008 | 12:30 PM
Websy21's Avatar
Another bump but really hoping that this current trade go's through!
Old Oct 31, 2008 | 01:25 PM
Intercooler2's Avatar
Interested in the Scanmaster. Can you PM me?
Old Oct 31, 2008 | 05:40 PM
blown00's Avatar
Here's a few pics I'll get some more up tomorrow.
Old Oct 31, 2008 | 06:27 PM
Websy21's Avatar
Pm sent, thanks!
Old Oct 31, 2008 | 06:31 PM
Websy21's Avatar
Attachment 152338
Attachment 152336
Looks good buddy, thanks for the pics. The deal is a go, we will definetly be doing business!
Old Nov 6, 2008 | 06:47 PM
Websy21's Avatar
Bump up!
Old Nov 7, 2008 | 09:35 AM
Websy21's Avatar
Scanmaster sold, turbo kit still needs a good home.... get it before someone else does on ebay!
I also have a stealth sub box with a He2 10'' and stealth amp rack too. This system pounded with only a 400watt amp.
Old Nov 9, 2008 | 07:55 PM
Websy21's Avatar
Price lowered, bump for the right crowd!
