Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
7 second project to a hault all parts for sale
Old Nov 24, 2010 | 12:18 PM
stangeater01's Avatar
Default 7 second project to a hault all parts for sale
Category: Audio/Video/Electronics
Price: $0
Part Fits: 93-02 Chevrolet Camaro
Location (State): LA
Item Condition: Brand New
LS Engine?: Fits LS Engine
1998 hard top formula car is a reconstructed title car was in the process of getting a 25.2 cage installed then through hardships couldnt be finished the floor bars were welded in but not finished i have all bars to complete cage, mini tubs are welded in motor plate and mid plate are in has doors glass front cap lights $4500 car is in New orleans Louisiana SOLD
427 lsx gm shortblock billet main caps priority main oiling 6 bolts per cylinder
callies dragonslayer 4340 forged 4.0 crank
oliver billet rods arp 7/16 bolts
wiseco 4.125 forged turbo pistons -32dish with heavy wall tool steel wrist pins .300 material above top ring land total seal stainless chrom rings for high heat applications clevite 2199 h main brgs with poly dyn coating clevite cb663 h rod brgs with poly dyn coating dura bond ch23 cam brgs arp main studs polydyne coating on pistons thermal coating on piston tops anti friction on skirts,
o ring block on 3axis cnc o rings included 1/2 head studs
cam motion solif roller cam(262/254@.050" 735/720 on 115lsa)
roll master double roller tinimg set with torington bearing and nitride gears
arp 2000 1/2"-7/17-8mm pro series 12pt head studs
melling 10296 coated high volume oil pump/ported pump
moroso lsx sheet metal oil pan with custom pick up tube with 2 turbo drain backs
ati sfi balancer arp ballancer bolt
gm ls2 front cover with cam sensor gasket seal and bolts
gm ls2 valley cover with bolts
LME custom oiling remote oil filter housing oil pressure regulator filters and fittings
as you can see the engine was built with only the best parts it is brand new never used to duplicate it would cost over 13k + build time
i would like to see $10500 shipped out the motor obo SOLD
106mm turbo kit designed by ky turbo forward manifolds all stainless turbo has dyno time only it is completely polished and cold side of turbo is v banded comes with a 5" down pipe with a vibrant "muffler" welded in to meet TRUE STREET classes has a brand new i will also include a 90mm v banded throttle body it has dyno time as well, 60mm JGS gate and has a used rechard racing intercooler purchased from FIREBALL which was on his 7 second ta looking for 7k for kit SOLD
rear billet specialities these are the all billet wheels they are double bead locked 15x12 5"BS 4.75x5 bolt pattern Billet Specialties Double Beadlock wheels. They come with both a chrome and black rings. Never mounted and NIB they are a match for the rear below 1500 SOLD
burkhart chassis chromemoly 9" narrowed 10" total has 325 gear spool wheelie bar brackets tiedowns anti roll alum center starflanged axles extended studs 40 spline axles have over 4k invested 3700obo
SOLD
matching LCA by burkhart 150 SOLD
burkhart chassis front bumper support coated metallic silver with afco radiator mezier remote water pump block fittings and custom crossover tubes comes with fan and shroud new 1200 SOLD
glassteck lift off ram air hood with custom bolt on rail kit done by madman 550 not painted but can arrange to be painted
ams 500 brand new mounted on a firebird ac/radio control bezel 325 SOLD
fire safety system bottle bracket line and hoses 175
tubular k member coated black no motor mounts not sure brand new 275 SOLD
billet tall valve covers with vac ports welded in comes with fitting installed but SOLD
billet motor plate polished to a shine LS design about 3/4 thick water pump holes are threaded 125
Old Nov 24, 2010 | 12:21 PM
Old Nov 24, 2010 | 12:41 PM
Old Nov 24, 2010 | 12:50 PM
Old Nov 24, 2010 | 12:58 PM
Old Nov 24, 2010 | 01:45 PM
jermzz's Avatar
can i get some bigger, better pics of the rear and rims?
jdresser1@comcast.net
Old Nov 24, 2010 | 04:10 PM
pm sent
Old Nov 24, 2010 | 05:01 PM
98zonjuice's Avatar
Still got that k member?
Old Nov 24, 2010 | 06:34 PM
its sill available
Old Nov 24, 2010 | 07:53 PM
CanuckSS's Avatar
Do you know the part # on the Stroud shoot? And does it have and SFI tag with an expiration date?
Thanks in advance.
Old Nov 24, 2010 | 08:21 PM
Gonoma's Avatar
pm sent
Old Nov 24, 2010 | 09:03 PM
i have a sale pending if it falls through i will let you know
Thanks in advance.
Originally Posted by Gonoma
pm sent
replied
Old Nov 25, 2010 | 01:39 AM
TRB02ss's Avatar
Is that turbo k member or regular k member
Old Nov 25, 2010 | 07:37 AM
it is dsigned for a turbo but there are NO motor mount ped. this is to be ran with a motor plate set up
Old Nov 25, 2010 | 08:05 AM
98Camarod's Avatar
are there bolt holes for them? pm sent
Old Nov 25, 2010 | 10:48 AM
Stingerrr85's Avatar
Really interested in fire system
what brand is it?
does it complete with all fittings and button etc
just want to bolt in when i get it
pm or textg or call me 773 656 5566
Old Nov 25, 2010 | 10:58 AM
replied
Old Nov 27, 2010 | 04:43 PM
pms replied to
Old Dec 1, 2010 | 08:38 AM
engine price reduced
Old Dec 1, 2010 | 08:16 PM
lt1camaroman93's Avatar
Is the k-member moly or mild and who's is it?
