Forged 370 w/patriot heads pre assembled build
I was wondering is someone could give me an estimation of my new build im figuring 500hp ..
TSP lq9 forged short block
Diamon -2cc flat top pistons
Stock gm crank
Ls7 lifters
7.4 hardened pushrods
Which injectors??
Patriot Stage II 2031 pre assembled heads
T56 routed back to stock 10 bolt
*Contemplating a moser 9" with 4.11s
1 7/8 " long tubes
Fast Lsx r 102 mm intake
With a thunder racing Trex cam .608/.612 with a 110 LSA
Going to be tuned by speed inc in Schaumburg, IL
What do you guys think do things look right? this is my first ls build.
The Cam I bought its the one i want i got it for a steal ($180)
The Headers I got with the car.
I am thinking pre assembled because i dont have a car as of right now. That was my only car.
Stock gm crank
Ls7 lifters
Which injectors??
1 7/8 " long tubes
thats to the wheels ?
If so what number have you guys put down at the track?
* DTSTI can you pm me and tell me a bit about your build any issues I should look out for, things you probably would do again with that set up.
still not together due to the fact i might be changing plans and going with a single turbo LQ9. but from what i see those heads and and a cam should put you close to 450-500hp on the high side but if you tinker im sure of it.
