Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
big cam, PP polished intake manifold, 4l80 deep pan, fbody oil pan/covers, powerbond
Old Sep 19, 2011 | 06:33 PM
Professor_speed's Avatar
Default big cam, PP polished intake manifold, 4l80 deep pan, fbody oil pan/covers, powerbond
Category: Accessories
Price: $1234
Location (State): MN
Item Condition: Brand New
LS Engine?: Fits LS Engine
This engine is still assembled I would like to sell either the heads or the short block before dissembley if someone is interested in the complete engine or a combination of parts we can work something out.
ETP 225 Heads set up with manley TI retainers and big springs. up too .670 lift iirc. set up for stock rockers, or stock replacement type rockers probably around 5k miles $sold (still bolted the engine) post#26 has more info on the heads
Cylinder Head: G III LS1 11° Application: Street / Race
Port Volume: 225cc Chamber Volume: 58cc
Test Bore: 4.000" Test Pressure: 28.00" Water
Intake Valve: 2.080" Exhaust Valve: 1.570"
Valve Lift Intake Exhaust Valve Lift
.100" 71 57 .100"
.200" 153 114 .200"
.300" 208 164 .300"
.400" 265 204 .400"
.500" 308 224 .500"
.550" 320 228 .550"
.600" 328 231 .600"
.650" 332 234 .650"
.700" 320 236 .700"
Exhaust to Intake Flow Ratio 73%
The springs are a 98445 part number from Competition Products,
The retainers are Manley ICD 23688,
springs are 155# on the seat at 1.750 installed. The coil bind was about 1.080
These heads went 10.110 @ 133.49, 1.455 60' 1968 Camaro, pump gas LS stroker 404cid 3300-3400# 23X/240X .65x/.65x cam (nothing crazy)
th400, 3.89 gear, drag radial, footbrake
Et calculators put that at over 600whp (take it for whats it worth)
Ls1 forged short block stock micro polished crank, Eagle h beam rods arp 2000 bolts, Mahle power pak -4cc pistons. built and balanced by wheeler racing engines in blaine Minnesota. no run time $sold
Arp ls1 head studs $sold
Professional products ls2 polished intake manifold (no rails) has felpro gaskets I can include. $350
comp 850-16 lifters no run time $sold
Double roller chain with slp pump for double roller no runtime on the pump 5k on the chain $sold
Fbody pan and pick up, no runtime $300
powerbond harmoic balancer standard size (no pics has a little surface rust) $100
248/254 on 116 +2 .605,.595 cam $200
cam cover, back cover, valve covers, $200
B&M Aluminum 4l80e deep pan NEW
$150 shipped
Slp ported oil pump (old version) 10k miles
$50 shipped
Plx devices wide band controller and 52mm black display used for maybe 20 miles
$160 shipped
new Gen Camaro Exhaust manifolds, sold
I have a wiring Harness and computer. its a NEW stand alone harness set up for speed density and t56 the computer is programmed set for start up vats and rear o2s removed, but will likely still need a tune. This was done by SP wiring. They even polished the ecu
sold
Hp tuners Pro NEW 8 credits the cable is still in the bag
sold
Aem low impedance driver box Used
sold
Edlebrock timing chain cover NEW ls2
sold
Derale 4l80e Deep pan with cooling tubes NEW
sold
Old Sep 20, 2011 | 12:34 AM
99Zblack's Avatar
Can you do $300 for the harness and computer?
Old Sep 20, 2011 | 08:06 AM
All pm's replied to
Old Sep 21, 2011 | 12:35 PM
To the top
Old Sep 21, 2011 | 06:42 PM
Timing cover is sold
Old Sep 21, 2011 | 07:58 PM
70lsgto's Avatar
Default hp tuners
so the hp was never used?
Old Sep 21, 2011 | 08:12 PM
That's right brand new never plugged into a car all 8 credits Never even registered. I just checked with Hp tuners and it good to go to the new owner.
Old Sep 22, 2011 | 03:34 PM
To the top
Old Sep 22, 2011 | 04:26 PM
gimmeluvin's Avatar
Where in MN are you from?
Old Sep 22, 2011 | 09:11 PM
brooklyn Park
Old Sep 23, 2011 | 10:26 AM
gimmeluvin's Avatar
Im in Plymouth, whats your bottom dollar? I can pick it up anytime.
Old Sep 23, 2011 | 01:24 PM
on what part? @gimmeluvin
Old Sep 23, 2011 | 07:30 PM
derale pan sold
Old Sep 23, 2011 | 08:44 PM
Hp tuners, harness, ecu and driver box sold
Old Sep 27, 2011 | 05:24 PM
All items have been shipped
Old Oct 25, 2011 | 11:10 PM
New parts added
Old Oct 26, 2011 | 05:43 PM
To the top
Old Oct 28, 2011 | 03:35 PM
to the top
Old Oct 30, 2011 | 01:30 PM
All Pms replied to
Old Nov 1, 2011 | 06:13 AM
To the top
