My oops with my built TH350 w/ transbrake, 20 miles on it ,my loss great deal LOOK!!!
Category: Drivetrain
Price: $500
Location (State): IN
Item Condition: Brand New
LS Engine?: Fits LS Engine
Comes with all of these extras!!
Lokar Flexible locking dipstick (per new NHRA rules-approved) $100 value
Derale Trans cooler with stainless braided lines $120+ value
Full fill amount of Royal purple max ATF trans fluid (extra comes with it as well), **** is expensive over $140 worth, drained the fill into a brand new sealed oil pan and have like 4 additional bottles.
had a oops with the trans today while pulling everything (motor and trans together), it hit the ground and dented the pan good, and put a small crack 1" in the case DAMNIT!
Of course the internals are fine and ONLY 20 STREET MILES on them. Guys are you looking to build up your th350 AND want a transbrake???? This has pretty much everything to do it. All that you need basically is someone (yourself or trans guy) to swap all of the guts into a new case (which are a dime a dozen) and you are good to go! drastically reduced price $500 gets all, absolutely firm on that, the brake alone goes for over $400 and has never even been used (never fully launched off of it, just tested it for 2 seconds to test functionality) EDIT after looking it over the case may be ok after all see below!
heres before the pan got screwed up...
Wow **** you know what I should have looked harder before instead of cussing at it and not looking it over , its really not that bad at all look.....
small 1" hairline crack does not even go into the "case" I could still recommend a small weld to avoid spreading...
Yeah the pan is pretty much shot, but tons of options for pans on these
Pan again
The side is sheared a little but will not affect the bolt up at all, so it looks like nothing has to be swapped! New pan, small weld for safety and thats it, I am not going to do a dick move and raise the price back up to what it was. Bottom line its a dirt cheap price, and I have no use for it . First $500 not a dollar less, first one to bring cash gets it
Pan again
lmk i work in the aviation biz and we dont have set schedules, and my next free weekend after this one is in 3 weeks
sale pending (to 2 people), no dibs, some of you guys say youll show and never do so no deposit and hold for 2 weeks or anything like that, first one with ca$h takes all!
