LS3 Intake and Other Stuff
Category: Engine - Intake/Fuel
Price: $300
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
A PTM 92 mm cable operated throttle body. Includes TPS, IAC, and 4 stainless bolts to bolt it on. It is brand new other than being installed. SOLD
An LS1 ECM that has the VATS removed along with the emissions and is tuned to run LS3 injectors and a stock LS3 cam. SOLD
A Mallory Racing Fuel Regulator for Fuel Injection (30-100 psi) Part number 4305M $85
A Used 255 Walbro High Pressure Fuel Pump. Flows 255 LPH. Comes with AN fittings on both ends. $80
A Brand New set of yellow valve springs off a set of LS3 heads. $65
I have a wiring harness I built to run all of these components together. It was lengthened to run into the passenger compartment on a 1984 Monte Carlo. SOLD
All prices are plus shipping.
Thank You!
pics of the wire harness and the pcm, i have a friend who is interested... and has a ss:
An LS1 ECM that has the VATS removed along with the emissions and is tuned to run LS3 injectors and a stock LS3 cam. $110
I have a wiring harness I built to run all of these components together. It was lengthened to run into the passenger compartment on a 1984 Monte Carlo. $120
You are interested in all of these parts? I have several people interested in the wiring harness and ECM.
The Intake has been SOLD. The PTM 92mm Throttle Body, Mallory Regulator, Walbro 255 fuel pump and the yellow LS3 valve springs are still available!
Also the PTM Throttle Body comes with the TPS and IAC valve. Along with 4 stainless bolts to bolt it to the intake.
