New stock fuel pump with filters
Category: Engine - Intake/Fuel
Price: $50
Location (State): IL
Item Condition: Brand New
LS Engine?: Fits LS Engine
Sold -- brand new LS1 F-body stock fuel pump never seen fuel. Includes brand new wires to bulkhead connector, pump filter, and bucket filter all of which have never been in contact with fuel. Compare with Rock Auto at over $300!!! These came out of a brand new fuel pump assembly I purchased. I did a Racetronix upgrade and these parts were left over. The flexible plastic fuel hose needs to be replaced because I had to cut the end to remove from bulkhead fitting (easily replaceable). The rubber pump case is used from a different fuel tank and has a cut in it so I could remove it (normal service procedure). Of course, you'll have your old case too if you're replacing a stock pump.
Sold -- used F-body stock fuel pump. Unknown condition or mileage. Came with a fuel tank I purchased out of California from a 2001 Camaro Z28. Needed the fuel tank for an LS swap project, didn't need any of the internals. Just pay shipping and I'll send it to you. This is a gamble!!! You might get a fuel pump gifted to you, or you might get a dud. You are not allowed to give me negative trader rating if it doesn't work. In that case just throw it in the garbage and say we tried.
Sold -- used F-body lower fuel bucket. Would be useful to somebody that has to cut holes for a Walbro pump. Use it for practice before you ruin your original bucket. This is from the same 2001 Camaro fuel tank mentioned above.
