Huge List of LT1 parts, Stock & Performance
Category: Accessories
Price: $1
Location (State): NE
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Fits LS Engine
STOCK
Alternator - $25
Starter - $25
Power steering pump w/ pulley - $25
Accessory bracket (for ps pump, ac, alt), powder coated gray - $40
Upper radiator support/shroud - $20
Fuel Pump/sender - $50
O2 sensors - $35 per pair
MAF stock with screen - $40
MAF Ported with no screen or center bar - $50
A4 & M6 Radiator - $50
Fans - $60
A4 transmission crossmember - $20
M6 Transmission crossmember - $45
Flexplate - $20
OBDI and OBDI pcms (will need programmed to your specific car) - $65
EBCM/ABS module/block - $25
Windshield wiper arms, $20 per side, $30 for both
Good working condition ac delco opti with 10k on it (95-97) - SOLD
Good working ac delco opti with 15k on it for 92-94 - $125
Vented opti electric and vaccum harness - $25 for the pair
Pair of 97-02 Tail lights - $30 each or $50 for both
Automatic Shifter assembly - $30
Automatic pedals - $30
Side mirror in black, sebring silver - $25 each side or $40 for both
Stock harmonic balancer pulley - $20
Black Berger panel - $85
Stock valvecovers - $15
Stock Oil Pan - $25
Stock valvecovers powdercoated red - SOLD
Rear main seal retainer, aluminum stock piece - $25
AFTERMARKET/PERFORMANCE
30# SVO Injectors, 4k on them - $145
Morel Linkbar hydraulic roller lifters, very low mileage - $300
Dynaspark Optispark for 92-94, converts your Gen I opti into vented without needing to convert anything else (was new on Nov 10, used during summer of '11 for 8k) - $375
Dynaspark - The last distributor you'll ever have to buy
JEGS SFI balancer and hub - SOLD
Aluminum Polished Valve covers with notch for alternator - SOLD
ATI neutral balance flexplate - SOLD
Granatelli MAF - $125
March Underdrive pulley for crank pulley, with bolts & belt- $45
Maximum ported LT4 Intake manifold, pm for more details, no longer powder coated - $375
MSD Coil 92-95 - $25
Taylor OTVC wires black without mounts - $60
Ebay CAI - SOLD
Madman altenator relocation bracket - SOLD
LT4 ED timing chain set - SOLD
Moroso 7 quart pan, black (similar to canton design without trap doors), specifically made for LT1 F-bodies. Comes with pickup needed - $200
Canton 242t oil pan, modified and sort of cobbled for fitment on a turbo car, will need repaired/rewelded, email for pics - $50
Pairs of poly endlinks (front or rear) - $15
HP motorsports torque arm, double adjustable with driveshaft safety loop - $200 (does require welding in the tunnel brace, near the drivers lca mounting point to further rigid the car)
I need the driver side mirror bracket, not necessarily the entire side mirror... My side mirror is fine just a broken bracket from some one leaning on it -_- would you seperate and how much?
