NEW LS6 Intake, Dynatech, Hooker, Lots of aftermarket new & used parts.
Category: Accessories
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NV
Item Condition: Brand New
LS Engine?: Fits LS Engine
BRAND NEW ITEMS
1. Dynatech LT Headers for Cadillac, Chevy, GMC, Hummer, 4.8, 5.3, 6.0, 6.2L, $750 shipped.
2. Hooker Headers, Super Competition, Full-Length, Steel, Ceramic Coated, Chevy, Pontiac, Camaro, Firebird, LS1. $600 shipped.
3. LS6 Intake. SOLD
4. Coil Packs for LS1/LS6. They were going to replace my stock units on my 2004 GTO. But I found out that mine were okay. $150 shipped.
5. 5 Gallon AL Fuel Cell. Comes with a set of steel powdercoated mounting straps (extra). Part # SUM 293205 $100 shipped.
6. LS Fuel Rail, SOLD.
7. Just Added: 60 lb. Edlebrock (Made by Siemens Deka) injectors. (60 lb. @ 45 psi, 72 @ 60 psi.). $275 shipped.
USED ITEMS
1. Set of Custom Forged 2618 Arias LS / LQ 403ci pistons. for a 4.005" bore, 4" stroke crank, and a 6.125" Rod. -3cc. .280 thick crown. Good for NA/Nitrous and blower friendly. They were removed only because I needed to lower the compression for a Turbo setup. 3,000 miles. $840 New - NEW PRICE $200. The #1 Piston has some moderate scratches on the Piston skirt. I believe it will need to be replaced. And the #5 piston has some scuffing on the top edge of the crown. I'm not sure what caused this, but this may or may not need to be replaced. Overall, 6 of the pistons are in very good shape, with minor
2. Edlebrock 90mm Ultra Low profile elbow. All mounting hardware and new gaskets included. Just as new. Used for a very short time. $75 shipped.
3. Griffen Radiator. Dual 1.25" row core, 2.75" thick. Total of 3" thick end tanks. this was run for a very short time, and was installed during a turbo mockup. Reason for the dings. Two mounting tabs were added at the top, and a -4AN bung welded on for the Steam Vents, coolant passage on the heads. SOLD. http://www.summitracing.com/parts/GRI-1-55241-X/
4. GTO Covers. $100 shipped OBO. Good condition.
5. LS6 Oil Pump removed from 2004 GTO. 32,000 miles. SOLD6. Derale 14" reversable fan. $70 shipped. It was used shortly with the Griffen Radiator I'm also selling. Very Powerful!
7. -12AN Earls Check Valve. $50 shipped. (Have 2 of them)
8. Just Added: 60 lb. Edlebrock (Made by Siemens Deka) injectors. (60 lb. @ 45 psi, 72 @ 60 psi.). $275 shipped.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG] Last edited by BlwnLs1GTO; May 17, 2012 at 08:34 PM.
EDL-3847
Take a look in the picture. That gasket along with the metal spacer is the provision for the early 3 bolt Style TB's. The elbow is also drilled for the 4 bolt pattern like the LS2 90mm.
Thanks.
Thanks.
Part number for radiator is 1-55241-X. It's a universal Rad. I spec'd this out for my build.
I added a link in the first post about it. The picture listed has different end tanks but I can assure you it's the exact same model.
Will do, thank you. If you want to send me a PM on a price, please do. If it's fair enough, I might just let it go.
Also, I have the stock Fuel line that attaches from the Rail to the Fuel Line outlet.
Yes I do. thank you.
