sheet metal intake, lsx accessories...
Category: Racing Parts
Price: $5
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
ls1 coils, brackets, harness, and bolts. 100 shipped.
alternator with mounting bracket 100 obo
power steering pump, with bracket, and lines 125 shipped
water pump no thermostat with tensioner 25 + shipping
fbody dipstick 15 + shipping
spohn sway bar mounts for aftermarket rear ends 30 + shipping
BMR battery relocation bracket 40 + shipping
alternator shield to protect from water if you have a tubular crossmember 30 shipped
customer 4inch intake pipe made for my 92 camaro with an ls1 swap. could possibly work in other cars. uses 85mm maf. 80 + shipping.
4l60e bellhousing 50 + shipping
custom sheet metal intake manifold. 90mm tb opening, is set up for direct port nitrous but has plugs installed as i never got around to spraying the set up. its fully ported on the inside. excepts factory intake manifold gaskets, comes with mounting hardware, brake booster line, map sensor, and pcv port installed. ideal for spray or boosted application. does not include injectors they are just in the picture for show, but does include high flow rails and -6an lines and fittings. 1400 obo + shipping.
i do believe the intake is priced accordingly but if you would like to pm with an offer i may consider it you never know
. also the intake has velocity trends ingraved on the top of the intake which was a speed shop in florida. not sure if its still around or not.
