"FASTEST CAM ONLY CARS" LIST.
Old Jun 28, 2004 | 05:33 PM
SMOKIN01TA's Avatar
Default "fastest Cam Only Cars" List.
With all the recent cam developments and new insane cam only times i thought it was time to make a list like the one for stock internals. talked to WILWAXU about it and im basing the format similar to the stock internals list. It will help all you guys who have been asking about the badest and fastest cams and what kinda setups they are running. These are all on stock heads,crank, rods and pistons.
Post up your times and ill bump and add folks. this should start getting interesting in a few months.
For Updates...
I need your ETs out to three decimal places, (i.e. 11.XXX) and include all the information require for the list.
..: Naturally Aspirated - CAM-ONLY :..
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Trans, Converter/Clutch, Gear, Cam, DA, Race Weight, Date
F-bodies Ls1/Ls6
  1. Smokin01ta ---- 10.219@132.29 (1.38), 01 TA, M6, Spec4, 4.56, TRex, -1100, 3010, 3/06
  2. LS1Joe----------10.232@132.04 (1.39), 02z28, M6, Spec4, 4.71, 250, -1100, 3150, 03/06
  3. 01-z------------10.295@128.48 (1.38), 01 z, Th400, 5500, 4.57, G5X4, -110,2880, 4/05
  4. Magnus -------- 10.295@128.48 (1.36), 97brd, T350, 5500, 4.10,G5X4, +200, 2820, 4/05
  5. Dragaholic-------10.340@127.46 (1.36), 00 SS, 350, 5500, 4.56, TRex, -700, 2850, 11/05
  6. SSmokedLS1 ----10.48@130.29 (1.45), 01 TA, M6, Spec4, 4.56, TRex, 800, 3035, 3/07
  7. Trevor @ TSP ---10.510@125.80 (1.43), 98 Z, 4l60e, 4500, 4.56, MS3, -1000, 3175, 2/05
  8. Project_SS ----- 10.561@126.74 (1.44), 98 SS,4L60e, 4400, 3.73, Vind, 2400, 2840, 7/07
  9. DMcRacer-------10.738@125.06 (1.46), 02 SS,4l60E, 4600, 3.42, AMS, -1080, 3375, 1/05
  10. Jason99ta------ 10.783@128.27 (1.56), 99 TA, M6, RAM, 4.56, TRex, +1300, 3253, 06/04
  11. Chrs1313------ 10.811@122.67 (1.386), 02 z28, SS4000, 230/230, 3.23, -400, 3275lbs, 10/08
  12. GrannySShifting 10.821@126.9 (1.47), 97 SS, M6, Tex, 4.56, PSI 233/238, -1000+, 3458lbs, 11/08
  13. PewterZ28------10.857@123.53 (1.46), 02 Z, TH350, 4900, 4.10, G5X4, +46, 3310, 10/06
  14. Coach02A3Z/28-10.917@122.97 (1.47), 02 Z, TH350, TK, 5.13, TRex, +2751, 3200, 06/04
  15. camscam02-----10.980@121.98 (1.47), 02 SS, 4L60E, 4400, 4.10, MS3, +290, 3370, 11/07
Corvettes Ls1/Ls6
  1. Roger White ----10.869@123.04 (1.46), '02C5, 4l60e, 4400, 3.90's, M2,-1000,3350, 11/03
  2. robz------------10.968@124.32 (1.46), 03Z06, M6, Cartek 3.90's,2x, -1000, 3250, 11/03
  3. REDGAR --------10.968@124.66 (1.50), 99vet, 4l60e, 5000, 3.90, VD, -800, 3400, 11/05
  4. BLU-BY-U------ 11.281@121.20 (1.51), 02Z06, M6, clutch, 3.90, RPM, -670, 3220, 1/05
  5. MadDawg------ 11.516@117.40 (1.64), 01C5, 4l60e, 3200, 3.15,Stealth2 -661, 3310, 2/05
Swaps/Hybrids Ls1/Ls6
Last edited by Villain281H; Nov 30, 2008 at 01:40 PM. Reason: Updating list yet again!
Old Jun 20, 2005 | 10:53 PM
I8AFORD's Avatar
update..11.28 @121.96 +700 DA..6/05
Old Jun 21, 2005 | 01:28 PM
PewterZ28's Avatar
How bout an update?
G5X4 time in sig along with DA and raceweight and converter.
Old Jun 22, 2005 | 09:34 PM
SMOKIN01TA's Avatar
Originally Posted by PewterZ28
How bout an update?
if yall want a update set it up like maddawg did in the post above, be sure yall remember to include all the decimals.
if you want to be updated i need to be able to copy your new info and paste in place of the old.
Old Jun 23, 2005 | 01:30 PM
PewterZ28's Avatar
Picky picky.
Here you go.
PewterZ28------11.037@121.65 (1.50), 02 Z, TH350, 4900, 4.10, G5X4,+1100, 3300, 06/05
Old Jun 23, 2005 | 02:32 PM
SMOKIN01TA's Avatar
Picky picky.
Here you go.
thank you good sir
im to lazy to write it all down and then go punch it all in
Old Jun 23, 2005 | 05:22 PM
PewterZ28's Avatar
Hmm, still no update.
Old Jun 23, 2005 | 06:11 PM
SMOKIN01TA's Avatar
im doing a lil houskeeping on the thread, all will be up to speed in a few days
Old Jun 27, 2005 | 10:26 PM
I8AFORD's Avatar
11.28@121.96 (1.54) 98 Z, M6, Spec 3, 4.33,G5X-2,+700,3500,6/17
Old Jul 6, 2005 | 09:11 AM
PewterZ28's Avatar
How about one last update for me? I finally made a 10 second pass so I'm going to lay low until the Fall now.
Here's the info:
PewterZ28----10.998@122.00 (1.50), 02 Z, TH350, 4900, 4.10, G5X4, +1378, 3300, 07/05
Old Jul 6, 2005 | 05:32 PM
SMOKIN01TA's Avatar
congrats guys, we now have 11 of 15 cars in the 10's
Old Jul 6, 2005 | 08:50 PM
Black8Banger's Avatar
man, i wanna get on that list soo sooo bad!
Old Jul 10, 2005 | 11:44 PM
ls1 joe's Avatar
New pb of 7-10-05
60' 1.497
330' 4.432
660' 6.889
mph 100.25
1000' 9.013
1320' 10.799
mph 126.01
Race weight 3240lbs
Baro 29.76
Humidity 64%
Temp 84.9
Update please
Old Jul 11, 2005 | 12:48 AM
SLP 02 SS's Avatar
Sweet.......Congrats on the New Times .
I've gotta get some Tranny work done before I can go Playin again.
It just won't hold the load.....Clutches starting to slip.
Pay-2-Play.
Getting ready to send it back to FLP and have it upgraded from
a "Stage IV" to a "Stage V" and move up to the Yank 4000
Old Jul 11, 2005 | 08:03 PM
SMOKIN01TA's Avatar
congrats on the improvements joe.
i know nobody reads the 1st post anymore so ill just keep copy and pasting this. if you want updates please type out the line just like it appears in the list with your new info in place of the old so i can copy and paste your knew stuff over the old stuff. takes to long to go back and forth to get all the info.
Old Aug 7, 2005 | 09:44 PM
ls1 joe's Avatar
Default new best
10.721@127.68 (1.47), 02 Z, M6, Spec4, 4.71, 250, 1500, 3210, 8/05
got a new best at the N/S shootout please update.
Old Aug 13, 2005 | 01:45 AM
SUX2BU's Avatar
SUX2BU 11.219 @ 117.94 (1.497 60') 98 Camaro SS, TA5300, 4.10, STOCK 98 CAM, DA????, 2985lbs 8/12/05
Old Aug 13, 2005 | 03:02 PM
SMOKIN01TA's Avatar
you need to post that on the SI LIST
Old Aug 13, 2005 | 03:17 PM
nomorews6's Avatar
These numbers are insane! I cannot believe someone is running low 10's with just cam/bolt ons. Unbelieveable. Actually, that is why I am writing. I do believe it, but my mustang buddy doesn't. What could I tell him? He thinks there are several liars or fudgers on the list (ie ... other things done to the motor). Edumacate me folks!
Old Aug 13, 2005 | 04:30 PM
nomorews6's Avatar
ps - is race weight with the driver or without?
