Who's ported their own heads?
more extreme. I can get a clean set of heads any old time
for $200 or so it appears. Grind back the valve stem bosses,
put a radius on the short side of the intake port, make the
bowls look smooth and polish the chambers all seem like
good clean fun. Though I saw somebody selling heads they
managed to bust into the water jacket so pointers would be
nice.
Who out there has had decent results (or exceptionally lame?)
from DIY porting? Anyone with a shade-tree shaving-maker's
guide to the LS1 casting?
I've got the itch to try....
I ported the crap outta a set of L-98 heads on my last car. Intake ports, exhaust ports, bowls, chambers...the works. The throttle response with those heads, relatively small cam (208/221 .474"/.510") and ported TPI manifolds was incredible. Made great power from 1200 to about 5800rpms which isn't bad considering it was TPI.
My best suggestion is not to try and shape with abrasive bits. They are more for smoothing and polishing. To shape you really need a carbide cutter. Talk to Mondello Technical school, they can get you started with everything you'll need including electric die grinders, carbide bits, and the right abrasives.
(805) 237-9185
Mike
About the same on the exhaust port but spend the time to polish it really smooth.Be really careful around the valveseats!!!Or you"ll be
tools (except I would have to go get some long shank
burrs, all of mine are short). But knowing when to
say when, and leave enough casting meat for good
reliability, is something I haven't got...
Maybe I can scare up a junker from the dealership
and section it, just for a little better idea of what
does and doesn't want cutting.
Have you seen APE's new setup? Damn those are some clean heads! I can't imagine those are done by hand. Does anyone know if machined heads are better or worse than hand ported heads? *Assuming an expereinced professional is doing both* I'm wondering what the Winston cup, NHRA, and F1 guys use?
Mike
how much are good cutters? im using a 1/4 air die...
I can't remember where I got the stone bits.
Summit used to sell a nice set of >"flapper"< rolls, they may still carry them.
I ported my plenum with the carbide bit, and my neighbor kept a nice constant spray of wd-40 on the bit while I cut. Worked real nice.
edit: I just realized what you guys meant by "flappers", Summit sell the rolled abrasives, cartridge rolls?
I was told by Mondello not to use flappers. The standard abrasives and buffer wheel should do the trick.
Mike
