Home heads Porters Come In
so I will be spending some time there as well doing research. I had my first set I did over a year ago flowed by Bennett Racing and they flowed 272/210 at .650 and they were 2.00/1.55 valved 5.3 heads and the last set I did were 2.00/1.55 valved 5.7 heads that flowed 272/205 @ .600, do not know what they did at .650. I think I lost a little flow on the last set because I heard that the truck exhaust valve flows a little better than the car valve, is this true? I asked Terry @ Racetech about it while he was still at PP and he said they do and I trust his judgement. All of my ports flow with in 3% of each other, I try very hard to match every port to the nth degree. Last edited by Bo White; Oct 12, 2004 at 12:50 PM.
Dave
Did any of you guys do any special seat work?Thats a good place to gain on a ls1 head.A local guy that did the valve work on my SB Chevy said he got 300 cfm on the first set off ls1 heads he did.
I also went thru on a set of iron Vortec heads(on the intake where the pushrods go by)and I brazed them back together,it was the most nervracking thing I ever done!!!These heads had been extensivly ported had bigger valves and studs and had been flow tested 2 times plus the combustion chambers were opened to match the 4.165 bore on my 408 SB.Every time the torch would POP I just knew I had cracked the head!!
Not funny!! Trending Topics
Brandon
The tools Summit sells is not the best. You need many shapes and sizes of bits to really do a good job. Some put wax on the bits to limit the chatter. A variable air pressure helps untill you know what you like. Always wear safety glasses, and headphones for tunes. You should really have one head to practice on - and when you get done, cut it up to look at cross sections.
FYI, I've done several sets and enjoyed the gains. Eventually bought a set of Patriot heads and had better results. After I bought valves, had a valve job, milled .030, bought springs and retainers it wasn't worth the effort. Between the overhead and time - I'll just pick up a CNC set where every port flows the same. Although, I am glad I did it, and at the time heads were $2,500 a set, not $1,200.
Good luck, have fun.
Brandon
