346LS1 500rwhp NA
Thanks
Aright guys, I'm ready for ya...
if your building a strictly 1/4 mile car work from the rear forward. you dont need alot of power to go fast in the 1320. traction and weight reduction go along way.
The T-Rex cam was never designed to run with modified cylinder heads. PTV with stock cylinder heads is close enough as it is. You'd be better off using a cam that is designed to work with ported cylinder heads.
check the drag racing forum and timeslip data base, look what kind of setups the mid 10's guys are running. theres more then one way to hit the same goal, 01-z just did 10.6@126 cam only, you can bet he's nowhere near 500rwhp
