346LS1 500rwhp NA
theres no static calculation, just gotta get out there and run. to many variables to could of, would of, should of.
http://www.web-cars.com/math/qtr_mile.html
http://www.geocities.com/MotorCity/4601/hpcalc.html
http://www.angelfire.com/rpg/dangrou...horsecalc.html
MANY more where those came from. Pick one...
.Another good example is Lee's (FEAR THE LS1) setup. He made 481 RWHP and 545 RWTQ and at a 3,470lb raceweight went 10.36 @ 131. Keep in mind he made that power through a TH400, 4" Steel Driveshaft, 12-Bolt, and 29" Slicks. At a 3,280lb raceweight he went a 10.11 @ 132 MPH. A 200lb drop in raceweight gained him .2, which is huge when you're in a class as close as Factory Stock.
The point here is that there is more to going fast than making good dyno numbers.
All it takes is $$$ and a willingness to have a 'track-only' car.
The T-Rex cam was never designed to run with modified cylinder heads. PTV with stock cylinder heads is close enough as it is. You'd be better off using a cam that is designed to work with ported cylinder heads.
Josh
Josh
Sure you can fly-cut the pistons and use modified cylinder heads, but that's never what this cam was designed for. It just happens to work.
with a 4400 stall, good luck getting 500rwhp
Now, the big thing is a good set of heads (AS, GTP, AFR225's, etc..), and a cam matched to those heads. I think you can go past 500 with a hyd roller, but you can't just look at more duration as the criteria for design.
I have some ideas in this area for some max effort stuff.
