FS:Ported LS1 heads, R1 cam, BMR Poly LCA's, 12 bolt gears, new Walbro fuel pump, etc
Old Mar 13, 2005 | 05:47 PM
WMSuperSport's Avatar
Default FS:Ported LS1 heads, R1 cam, BMR Poly LCA's, 12 bolt gears, new Walbro fuel pump, etc
I am selling these parts to upgrade to my new setup.
I have:
Ported LS1 heads. 2.02" intake valves,1.57" exhaust valves, I would consider it a 1.5-2 stage head. Milled .015". It was ported to produce high flow at WOT while maintaining proper velocity through the runners and lower RPMs. Ferrea valves, bronze guides, new rubber valve seals, and I'll throw in a brand new set of Comp 915s, which are a little better than stock but alot stronger. These heads have 2K miles at the most and are in excellent shape. A great deal for someone looking for a low priced ported set of heads. $700 O.B.O. I'll work with you.
R1 cam. Jay Johnson ran a 9.xx with this cam in a 346 and I am going bigger so I am letting it go. It has maybe 5-6K miles and is in awesome condition. I'll let it go for $250 O.B.O. Ill work with you.
BMR Fully Adjustable Chromoly silver poly/poly Lower Control Arms. I bought them from Jay Johnson and never installed them. The bushings look almost new and there are a few scratches on the paint, but you can't see the arm from a standard view anyway...$110
Moser 12 bolt 4.11 gears. 200 miles MAX and do not whine. I installed them once and took them out immediately because it's too much gear. No track time, just street fun. And moving to this gear will definitely pack a punch! $75 O.B.O.
Brand new Walbro 255l/hr high pressure fuel pump(LS1 style) with screen, hosing, clamps, instructions, wiring, seals, etc for any LS style fuel system. Never took the caps off the pump, just opened the box. Never tried to install or anything. Good as Brand New! Just won't support my fuel needs with N02. $100 O.B.O. Also negotiable...
TNT Nitrous dry 75-100-150 shot kit with two bottles ran through it. I won't be needing this anymore so it's up for grabs. Comes with everything needed, wiring, selenoids, jets, adjustable pills, lines, relay, etc. I mean this kit made my lame 320RWHP into a monster! $350 O.B.O. I'll work with you.
1 Prostar skinny(15"x3.5") with almost new tire. Chrome is in great shape. Shipping would be an issue unless you live in the DFW area. $100 O.B.O. I'll work with ya.
All prices are negotiable and may or may not include shipping. Feel free to ask questions at my email WMSuperSport@cs.com. Thanks
Wes
Old Mar 14, 2005 | 08:57 AM
shkettle's Avatar
might be interested in pump and nitrous kit-call 678 656 6597 shaun
i live in atlanta, but will be in houston on all next week.
Old Mar 14, 2005 | 09:38 AM
FungusMungus05's Avatar
I have:
Wes
I'll buy your TNT kit, and I'm in the DFW area.
I sent you a email and pm over in LS1.com
Old Mar 14, 2005 | 09:42 AM
I have:
Wes
PM sent
Old Mar 14, 2005 | 09:45 AM
ssheets's Avatar
Dibs on the gears if they fit...and maybe the fuel pump?
Old Mar 14, 2005 | 10:40 AM
Tiger2o69's Avatar
Thats inline right. Will it support 400hp + 200 shot nitrous ? ~600hp?
Old Mar 14, 2005 | 11:57 AM
JayLS1-327's Avatar
Pic of the Weld ?
Old Mar 14, 2005 | 03:23 PM
svenh44's Avatar
Originally Posted by JayLS1-327
Pic of the Weld ?
sent you pm about gears and lca's
Old Mar 14, 2005 | 04:07 PM
Blue02Ws6's Avatar
The fuel pump shoul dbe an intake pump, if the other two don't buy it I will.
Old Mar 14, 2005 | 04:54 PM
Fuel pump, LCA's, and gears are progress. Everything else is still for sale....thanks,
Wes
Old Mar 14, 2005 | 05:33 PM
camz383's Avatar
I want the lca's asap, let me know if anything happens... pm me... ill take them!
Old Mar 19, 2005 | 12:08 AM
camz383's Avatar
did the lca's sell, if not i will take them asap
Old Mar 19, 2005 | 12:27 AM
NVR4GET's Avatar
Got any flow numbers for the heads?
Old Mar 19, 2005 | 12:35 AM
Tim 98z's Avatar
That's about the exact cam I have been looking for. What springs did you run with it? Which are recommended?
Old Mar 19, 2005 | 08:43 AM
camz383, I'm awaiting payment on the LCA's, but I'll keep you on the list.
NVR4GET, sorry no numbers on the heads
Tim98z, I use Comp 918s, they are very safe with this cam. I have a low milage set if you want to buy them.
Thanks guys,
Wes
Old Mar 19, 2005 | 09:36 AM
Tim 98z's Avatar
I have 918's and that's good to hear. You got a PM.
