Lots of ls1 engine parts
All of these parts came from a 2000 camaro ss with 55,000 miles on it. All parts sold as is.
Let me start out by saying I hust put what I thought was reasonable for these parts as a price. Please shoot me an offer if you disagree with a price. Thanks
Coil Packs w/ harnesses and brackets----SOLD
Knock sensors w/ harnesses and rubber plugs----SOLD
Plug wire set (mixed brands) w/ shields and springs----$10
Fuel injectors w/ rail and regulator----SOLD
Motor Mounts & brackets----$75
Throttle body w/ sensors----SOLD
Water pump w pulley and thermostat housing----SOLD
Intake manifold----SOLD
Map sensor----SOLD
Flywheel has good ring gear, needs surfaced----$50
Oil pump pickup----SOLD
Windage tray----SOLD
Crank position switch----SOLD
Distributor pickup sensor----SOLD
Valve covers w/ oil filler & cap & mounting bolts----SOLD
Set of stock pushrods----$10
Valley cover w/gasket----SOLD
Crankshaft w/ trigger wheels----SOLD
Cylinder heads w/ springs, valves & rockers----SOLD
Oil pan w/ baffle----SOLD
Dip stick & tube----SOLD
Timing chain & gears (crank gear is knicked on the side, but should be good)---$5
Harmonic Balancer w/ bolt----SOLD
Oil pump----SOLD
Camshaft ------------$20
lifters and holders----SOLD
Piston & rod set has one damaged piston----SOLD
Front engine cover w/ gasket and bolts----SOLD
Rear engine cover w/ gasket and bolts----SOLD
I am open to offers on these parts. Please PM me with requests.
I am open to trade for a good celeron d socket 478 processor, or a pentium 4 processor----Thanks
Map sensor----SOLD
Oil pump----SOLD
