LS2 vs Fast 90 dyno comparison
Old 11-05-2005, 09:24 AM
lt1dave's Avatar
Default LS2 vs Fast 90 dyno comparison
This is a customers car I just tuned with a fast 90/90, then installed a LS2 we ported to see the results. Its pretty surprising how close they are.
Mods are My 234 custm grind cam, patriot stage 2 LS6 (out of the box), pacesetters, magnaflow catback, ASP, 9inch(4.30s).
The difference of the fast 453/404 vs ls2 452/406 isnt too horrible. The fast pulling higher on the top would make the car probaby a tenth faster.
http://lt1dave.com/media/ls2%20vs%20fast90.bmp
Old 11-05-2005, 09:33 AM
LS1 Tech Administrator
Patrick G's Avatar
Holy download time Batman!
Interesting graph, but the FAST gains up high look more like you're having valvetrain stability problems since you installed the LS2 intake. The RPM falls too fast to be airflow related IMO. Also, the FAST loss down low does not match any of the comparisons I've seen on this board in the past. Normally, the stock, unported FAST maintains the torque down low, then pulls away up high. Do you know what kind of correction factors/weather conditions you had from one month to the other?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-05-2005, 10:00 AM
lt1dave's Avatar
Its not a valvetrain issue, or any other issue at all. This is just a comparison. Both A/F ratios wer dead on 12.9-13.0, SAE correction on a dynojet. Fast went backon for later pulls, and the numbers repeated.
The fast defineatly made about anoter 10 hp up top, but the LS2 made more mid/low numbers by about 10. Porting the LS2 changed the intake DRAMATICALLY, so it wont be even close to any charts you have seen in the past.
Old 11-05-2005, 03:42 PM
Super Hulk Smash
JakeFusion's Avatar
So, the LS2 was ported? Was the FAST ported or port-matched as well?
Old 11-05-2005, 04:17 PM
Nate_Taufer's Avatar
can you pm me a price of your ported ls2 intake and will a 90 mm tb work with it?
Nate
Old 11-05-2005, 04:18 PM
Mr Powell's Avatar
Thats wierd we lost power switching from a LS6 to a LS2.. So we bought a FAST 90/90 we will have back to back dynos really soon.
Also something to think about.. The LS2 intake stock flows around about the same as a stock LS1 intake. I dont think it could be ported to the levels of a LSx 90.
Old 11-05-2005, 08:02 PM
lt1dave's Avatar
This LS2 is ported. The FAST intake was ported as well. You may THINK it cant come close from porting, but the dyno numbers dont lie. I seriously doubt you could lay down 450rwhp with a a LS1 intake on a stock bottom end with this small of a cam. so the ported (LS2) intake obviously is way out flowing the LS1 or even the unported stock LS2.
Old 11-05-2005, 08:22 PM
TAF Motorsports's Avatar
The dyno pic is blacked out
good stuff dave
Old 11-08-2005, 01:39 AM
HammerSandwich's Avatar
lt1dave, load that file into the Paint program. Go to the File menu and select Save As. In the Save as Type box, choose either PNG or JPEG for dramatically reduced file size.
Old 11-08-2005, 07:18 AM
Worm's Avatar
Yeah Jpeg for christsakes!
This is a stock bottom end and you're spinning it to 7K+?
Nice comparison thanks!
Old 11-08-2005, 07:37 AM
SideStep's Avatar
Hey, I resized graph to make it a little more browser friendly...
What areas did you hit when porting the LS2 intake???
Very interested!!!
Old 11-08-2005, 07:50 AM
lt1dave's Avatar
Thanks. Im a mechanic and tuner, but not much of a computer wiz I guessLOL
Most of the work is at the entry of the runners inside the manifold. They are horrible in as cast form, and wont flow well at higher rpm. I cut open the intake and pretty much redesigned the runners. I expected to loose some (allot) of low end tq because of it, but as you can see, it didn't. It was certainly allot closer to the fast than we thought it would be.
As to the question of a stock bottom end spinning 7k. We do it all the time. Just add some rod bolts. Ive yet to loose one! (I shift mine at 7400!)
Dave
Old 11-08-2005, 08:08 AM
Gunnar@Patriot's Avatar
Great info, Dave
Old 11-08-2005, 09:54 AM
eb02z06's Avatar
Yes please post more info about the LS2 intake
Old 11-11-2005, 04:23 AM
speedo's Avatar
So in real world drag racing.... even know the FAST has more up top and the LS2 has more down low which intake will be faster on the track?
Wish I had some extra cash for a dyno....(kinda saving up for a 402) but I have a TPIS 75x90 oval intake and TB on the self and a 90 Fast intake and TB on the car now I would love to do a swap on the dyno just to see what is up.
I really feel since I went to the 90 Fast intake I have lost low and midrange but the top feels the same. So I am up in the air....
Old 11-11-2005, 08:44 AM
lt1dave's Avatar
At the track, I would expect to see a min. of a tenth gain from the FAST over the LS2. This is due to the fact that your not going to hit the rpm where the LS2 is making more power, but you will hit the high rpm where the FAST makes more.
If you didnt port your FAST, Id say you didnt pick up a much at all over the 90mmLS6, especially if you havent dynotuned to optomize. The FAST leaves alot to be desired in unported form, especially for the price.
Dave
Old 11-11-2005, 03:32 PM
speedo's Avatar
Yep I hear yea....Just waiting till spring to get down to Speed inc for a decent dyno tune... Still running on a mail order tune now.
Ok who ports these Fast intakes and do you need the heads? Can you just do a one size fits all porting. Or should I just wait until I get a new set up.
I plan one getting new heads with a 402 as soon as this stocker goes BOOM so I don't want sink to much money into this setup for now. Would like to see 440 to the rear however so I don't feel like I wasted money now.
Old 11-12-2005, 01:13 PM
lt1dave's Avatar
We port the FAST every time we install one. Most of the work isnt in the runner, so it can be done independant of the heads.
Old 11-12-2005, 01:24 PM
JS
JS's Avatar
I ported my LSX/90TB myself
Results over the LS6/78TB were 1.6ET/2MPH
I'd port it if your going to the trouble of putting it on..
I'll be adding one to my GTO,even with a small cam there worth 15RW....
Old 11-12-2005, 07:39 PM
uberLS-1's Avatar
This was comparing a ported manifold versus one out of the box....close still. But the LS2 is maxed out, if they were the same cost I would still get the FAST simply to have room to expand in the future....but wouldn't dare put it on unported.
Quick Reply: LS2 vs Fast 90 dyno comparison
