LS1 TH350 Conversion - good for 900hp
$500 pickup or $550 shipped anywhere in the 48 state US.
This custom built street/race transmission was built to live behind a 9 sec car. It was
Stahlnaker Racing Transmissions Ultimate TH350 - built to handle 8/9 second passes all day long, and complete daily driverable & streetable in everyway.
Transmisison is brand new built, gaurenteed to be in perfect working order on installation. It has never been installed and is completely new.
Was built specifically for use behind th350. Uses long tailshaft specific for bolting directly into your f-body
Also has full 1 year warranty gaurantee on labor.
I accept all forms of payment (paypal, moneyorder, cash if you pick it up)
I can ship it fedex ground anywhere in the country in a rubbermaid style tub.
I currently have a stock M6 tranny. Do you know if I can use the same driveshaft that I have now with your TH350 tranny? I have heard that it needs to be a 9" tailshaft, otherwise, a new driveshaft....
People asked some details of the internals..heres some stuff I have on it.
Its setup to work with a stock A4 shifter. I have a high dollar baddude continental converter for it but i didnt plan on letting that go.
3 Alto Red Eagle intermediate clutches .098
3 intermediate Kolene steels .068
5 Alto Red Eagle direct clutches .098
5 Direct Kolene steels .068
5 Borg Warner Forward clutches .098
5 Forward steels.068
5 Borg Warner low/reverse clutches .098
5 Low/reverse steels (Turbulator) .068
New intermediate sprag race (heavy duty)
Complete set of heavy duty bushings including teflon extension
Set of thrust washers w/plastic output shaft pilot
Street/Strip Custom Shift kit
Heavy duty red lined intermediate band (welded)
New intermediate sprag (NDH)
New low/reverse sprag (NDH)
New adjustable vacuum modulator
Set of sealing rings (teflon stator & cast iron accumulator rings)
New governor gear
New front pump & governor filter
4 Piece case saver
New governor gear
4 Piece case saver
