Built 4L60E & Parts For A4 Swap
I had this transmission built by Texas Best Transmissions in Arlington. It has 2000 miles on it. I have a reciept and the following is a list of parts used when it was rebuilt:
4L65E 5 pinion planetery set
4L65E Input Sprag
Beast sunshell with reaction shaft 4L65E bearing
Wide band HD Kevlar
Banner kit master/with Koleen steels / HD red clutches
HD center support
Capsual for release on servo
1-2 Super servo with rubber viton sealing rings
Cryogenicly hardened input and output shaft
4th gear Super Servo with dual piston
Pinless accumulator pistons
Z-pack (3-4) 14 one sided clutches
Stiffener plate
Transgo shift kit
wiring harness
All new solenoids
Bushing & Bearing kit
Deep pan
$900.00 plus shipping (probably around $120.00 - $150.00)
Stock aluminum drive shaft with HD Spicer U-joints $100.00 plus shipping
Blue Center console $60.00 shipped
Stock shifter $45.00 shipped
Stock Flex plate $45.00 shipped
4L65E Input Sprag
Wide band HD Kevlar
HD center support
Stiffener plate
Transgo shift kit
wiring harness
All new solenoids
Deep pan
There is nothing wrong with it. I'm converting to drag only car. I will be installing either a TH350 or 400, I havn't decided yet. The car will not see any street use so I don't care anything about having an OD transmission.
