Ford 9", TH350 Swap, Weld Pro Stars w/ MT's, Hooker Headers
I'm selling off some of my extra parts.
1999 Red Z28 Roller (No Title) 3" Cowl Hood, Been clearanced for big tires 325/50/R15 or 28x10.50W's, 3.23 Rearend, Leather Seats. Needs paint on front. $1500 - SOLD
Ford 9" 4.56 35 Spline Moser package with Strange Aluminum Center Section (Brand New) Lightened Spool, 1350 Yoke, Daytona Aluminum Pinion Support, Big Ford Ends, C-Clip Eliminators, The best of everything $2300
15x3 w/ 165 Radials & 15X10 Prostars w/ MT ET Street Radials 325/50/R15 (less than 200 miles on both) $850 - SOLD
Hooker LS1 Headers and X-Pipe $450 - SOLD
TH350 LS1 Swap, TH350 Longshaft, Reverse Manual Valvebody, TCI Deep Pan, 10" TCI Race Convertor, LS1 Adapter, LS1 Trans Crossmember w/ Mount, and LS1 TH350 Flexplate (All New Parts) $1300 - SOLD
Lingenfelter 3.5" Aluminum Driveshaft $150
Timing Tuner $100 - SOLD
17X9 & 17X11 ZR1 Wheels rears have 335/35/R17 tires that are good for dry use only $600 - SOLD
MSD 6AL (Brand new in box) $175 - SOLD
B&M Ripper Shifter $100
Mahle Motorsport Forged 347 cid LS1 Flat-Top Piston Set: 3.908" Bore, 3.622" Stroke, 6.098" Rod Length, .945" Wrist Pins, 1.314" CH, -4cc Dish; Wrist Pins and Piston Rings Included. $500 (Brand new in sealed box)
Comp Cam Pro Magnum 1.52 Rockers Half Set $100 Brand New In Package
Crane Cams Solid Roller Vertical Bar Lifters $200 Dyno Time Only
Weld Pro Stars Rear Only 15X8 5.5BS with MT 26X10 ET Drags $250 - SOLD
Thanks Scott
Thanks Scott
Captain InsaneO - PM replied.
4thGenCamaro & cablebandit - I have $360 in each rear wheel & tire, and $190 in each front wheel & tire for a total of $1100 so $850 is 33% off off of cost. That then would make the fronts $300 and the rears $550
Thanks Scott
Thanks Scott
I am interested in the roller and the wheels/tires.. Send pics and all info on the car to Matt_Shabani@Yahoo.com
Why doesn't the car have a title? Is there any way to get a title on it? Let me know about all of this stuff and what all is included with the car.. Also, how much for the car with the wheels and tires??
I would like pics of the roller also waynej@net-change.com
BTW can you get a title even if it's salvage.
