SAM's 500" LS2 Project *Progress Pics*
Old 02-21-2006, 08:16 PM
BigBronco's Avatar
Default SAM's 500" LS2 Project *Progress Pics*
Here is some info and pictures of our 500 cubic inch ls2 project we have been currently working on here at the school.
Some information about the motor:
Bore - 4.2025" Outfitted with Custom Wiseco 26cc Dish Pistons
Stroke - 4.500" = 500 Cubic Inches
Connecting Rods - 6.800" Carrillo Billet A-Beam
Cam - Custom ground Comp Cams Hydraulic Roller
Heads - LS7 heads that have been cleaned up
Intake - Factory LS7 Intake
This is hosting ERL's Deck Plate and Sleeving they are offering to help allow us to reach the 500 cubic inch limit.
We are right at a 10.9:1 compression ratio and we are looking to make around 650 to 700 horsepower Naturally Aspirated on Pump Gas.
Now time for the Pictures:
I will be adding more pictures here shortly.
Also, the other motor in the background is our C5-R project motor. I will give more specs on that if you guys would like. We are aiming to make around 900 horsepower on motor with that setup. I will post a few pictures of that motor as well!
For other info on the school, just check out our website www.SAMracing.com or you can shoot me an email at Gray@SAMracing.com.
Regards
Gray Arrington
School of Automotive Machinists
UPDATED LS7 CYLINDER HEAD AND INTAKE PICTURES ON PAGE 3
Old 02-21-2006, 08:31 PM
67Ranger's Avatar
That looks about amazing, I'll definetly have to come check that out whenever i come for my visit.
Old 02-21-2006, 08:57 PM
jrp
SN95 Director
jrp's Avatar
gray, have you guys test fitted the clearance's yet of the motor in the chassis. and i assume this is gonna be one of SAMS drag only cars? who are you guys using for the custom headers?
Old 02-21-2006, 08:58 PM
BigBronco's Avatar
More Pics: Shots of the pistons, wrist pins, ands rods
Thanks for the compliments. You know you are definately welcome to come by and take your tour man!
Old 02-21-2006, 09:06 PM
Brandon Boomhauer's Avatar
Looks nice and expensive.
Interested in hearing about the fitment in the chassis aswell.
Old 02-21-2006, 09:07 PM
MadBill's Avatar
Love to hear more re your C5R! I've done some preliminary engine simulations for a 14.0:1 7.0 L. C5 road racer with ET C5R style heads and an IR manifold, and I thought I was getting some GIGO effect with my sims, as it looked like 900 HP would not be a stretch...
Old 02-21-2006, 09:27 PM
Florian's Avatar
stellar!
F
Old 02-21-2006, 10:46 PM
BigBronco's Avatar
Test fitment will be coming soon as we will be preparing our Black Z28 to use at the car of choice. As for long tubes, that is up in the air. We might make them, but we are not too sure. I will give you a better update tomorrow after speaking with Judson, Pat, Casey, and Brandon!
Here is a "part" of our C5-R (Our Custom Beck Sheetmetal Intake)
As for the C5-R, we are running right at 16:1 compression. A very small chamber and tiny dome on the piston. We have a pretty radical cam that will be in the motor as well. It is in Excess of .920 lift on the intake side and .880 on the exhaust. Duration is 278/290 and a 114 LSA. We are getting ready to add the MSD belt driven distributor, MSD 7531 ignition box, and Big Stuff 3 to control the injectors. I will also keep you up to date as this motor comes together as well.
Old 02-21-2006, 11:25 PM
| Powered by Satan |'s Avatar
i have seen both motors in person... both are bad ***! i cant wait to see the numbers1
Old 02-22-2006, 12:33 AM
mr2guru's Avatar
So is the idea to just go ahead and run diesel? or ???
Old 02-22-2006, 12:50 AM
gnx7's Avatar
Holy schmoly! That will be one torquey SOB.
What is the potential redline for the 500" motor with a 4.5" crank? That is one long throw.
What does a 4.5" crank weigh approx. in relation to a 4" crank? I'd love to know.
Old 02-22-2006, 12:59 AM
99ssleeper's Avatar
Man that's cool stuff. I've been thinking about coming to SAM...looks like it would be a very good experience.
Old 02-22-2006, 12:58 PM
xfactor_pitbulls's Avatar
Originally Posted by gnx7
Holy schmoly!
I am curious about the same thing. With that size cam, compression, and setup I am sure it would pull to 8K. But would you feel comfortable pushing it that high. What would the fps of the rotating assembly be at around 7K?
Brandon
Old 02-22-2006, 01:01 PM
EVIL TA's Avatar
i'll take one gray!!!!
Old 02-22-2006, 01:08 PM
THE_SUPRA's Avatar
i'll have 2 please
Old 02-22-2006, 01:25 PM
The Juggernaut's Avatar
Can you run big compression on that deck plate?
Old 02-22-2006, 01:40 PM
BADSZ28's Avatar
Do the holes in the pistons for better ring seal lower the compression? Are they OK for street use? Will they clog over time? What are the downfalls of using these? DO they need to be custom drilled or can you buy them like that? Is the rotating assembly going to be coated? How about the heads, will they see coatings? Is the block going to be coated (well sleeves)?
Old 02-22-2006, 01:52 PM
BigBronco's Avatar
Brandon
The Piston speed is going to be right at 5250 at 7,000 rpms.
Our C5-R has the same piston speed at 8,000 rpms.
We are going to keep it nice and safe and churn it around 6800 to 7000 rpms.
Old 02-22-2006, 01:55 PM
BigBronco's Avatar
It should be alright with higher compression setups because of the 1/2 studs the motor incorporates with the motor. Definately will have to see how it does with babysteps. One at a time.
Old 02-22-2006, 02:03 PM
BigBronco's Avatar
The vertical gas ports that you are referring to will most likely clog up in time but should last for quite a while before doing so. You can get these pistons like this from wiseco, je, or which other manufacturer that is out there. Vertical and horizontal gas ports are now showing up in a lot of different sets in high performance applications.
We are not running anything coated in our motors. Only thing coated is our clevite bearings that we are running in our C5-R motor mains. Other then that nothing at the moment is coated. I am positive you can coat what you would like from places like Polydyne, etc.
Sleeves are not coated, nothing is going to be coated, but if that changes I will definately update my post.
Quick Reply: SAM's 500" LS2 Project *Progress Pics*
