Race Torque Arm, LCA's, Battery quick disconnect, NOS bottle brackets
Old May 13, 2006 | 06:11 PM
383LQ4SS's Avatar
Default Race Torque Arm, LCA's, Battery quick disconnect, NOS bottle brackets
This TQ arm was Fabbed by Brandon Aders and myself. Its a beefier version of the Madman style tq arm but it is removeable since all attach points use bolts. It is to be used with BMR boxed subframe connectors and bolts in to the subframes and the crossbrace pads under tha car. It has a BMR rear TQ arm mount that will bolt up to a 10 bolt or a 12 bolt. 5 adjustment holes for best instant center and adjustable for pinion. Integral DS loop and a notched area for additional exhaust clearance for true dual exhaust or a Y pipe will fit through with little modification to the Y pipe. All tubing is chrome moly for the Tq arm. The cross brace is actually stinless steel.
This is not for the novice. Its for someone that knows how to set up a suspension..as the adjustments are very important to performance. I went many 1.3x sixty foots with with a 6 speed with this setup and it will handle ALOT more. I want $650
BMR double adjustable LCA's I believe new they are around $180 from BMR. Ill sell these for $125
Elcon battery quick disconnect for aircraft. allows you to wire one end to your battery in a box and the other end hardwired to you car. You can then swap out batteries or disconnect batteries with a full turn of the handle. I have two for batteries and one for the car. Very convienent if you switch batteries or just need to disconnect in a hurry. Handles 1500+ amps. The green Elcon new is about $300. Ill take $75 for all three pieces plus hardware and terminals.
NOS aluminum quick disconnect bottle brackets. I installed real QD pins in the hinges as well. $75
Old May 13, 2006 | 08:51 PM
383LQ4SS's Avatar
ttt for the night
Old May 13, 2006 | 09:40 PM
KAOS's Avatar
could i get this to work with tubular sub frames? looks like a good setup. what could i do to make it work with the tubular setup. and do those lcas make any noise?
Old May 13, 2006 | 10:26 PM
383LQ4SS's Avatar
it MAY not be a direct bolt in with tubular sub frames. Although if the width is right you would just drill holes in the tubes to mount the crossbeam...maybe take up the extra space if there is any with some washers? It wouldnt take much from someone who knows how to weld and fab a bit to get it to work though.
The LCAs have the high durometer poly bushings so they are queit.
Old May 14, 2006 | 12:34 AM
RedRyder518's Avatar
Very interested in the LCAs. Sent you a PM.
Old May 14, 2006 | 01:22 AM
383LQ4SS's Avatar
pm returned
Old May 14, 2006 | 02:00 AM
blue01ta's Avatar
pm'ed ya.
Old May 14, 2006 | 10:02 AM
383LQ4SS's Avatar
LCA's are spoken for
Old May 15, 2006 | 08:07 PM
383LQ4SS's Avatar
TTT for the evening
Old May 15, 2006 | 08:41 PM
KAOS's Avatar
i wish this was a different time, i would own it all but tt for ya anyways
Old May 15, 2006 | 11:34 PM
383LQ4SS's Avatar
Make me an offer
Old May 16, 2006 | 08:54 PM
383LQ4SS's Avatar
PMs returned
Old May 17, 2006 | 06:40 AM
squealingtires's Avatar
That looks beefy! Good Work!
Old May 19, 2006 | 02:45 AM
383LQ4SS's Avatar
Still for sale...make me an offer on the tq arm.
