Ls Motor Parts and trans adapter
Old May 29, 2006 | 12:09 AM
redline2k's Avatar
Default Ls Motor Parts and trans adapter
All parts are used and DUE NOT include shipping:
Complete set of coils and brackets and bolts 125.00
starter and bolts 75.00
stock flywheel for m6 25.00 needs to be turned
stock rods and pistons out of 60k 98' motor 40.00
jw. performance adapter and flex plate with all the hardware to bolt on a turbo or glide trans using a stock style turbo convertor. 275.00 New never used still in box.
Updated
Old May 29, 2006 | 01:05 AM
Syclone354's Avatar
are the alt/bracket f body or corvette?
were the coils working when removed? same with starter? if so please pm me info on costs with shipping to 21157.
Thanks!
Old May 29, 2006 | 01:06 AM
Syclone354's Avatar
oh and would the adapter and flex plate work for my 4l80e? its like a 93 trans thats currently bolted to my 4.3 v6 in my syclone. if so let me know price shipped to 21157 also! THANKS!
Old May 29, 2006 | 09:16 AM
redline2k's Avatar
Thanks!
All parts are f-body.
Old May 29, 2006 | 09:27 AM
redline2k's Avatar
Not sure what you are trying to do, but this is made so that you can adapt a th-350 or 400 or glide to an ls engine and still use the old style convertor.
Old May 29, 2006 | 09:28 AM
Syclone354's Avatar
I had read somewhere about a "crank spacer" so i could run my converter i have now on the lq9 engine. The converter i have now is a hughes 3500 and uses a standard 3 bolt connection to the flexplate.
Old May 29, 2006 | 10:59 AM
idf1966's Avatar
I'm interested in the oil pan and pick-up. Will you ship to Canada? If so, is it possible to get an estimate to Postal Code J8N 7R7?
Thanks.
Old May 29, 2006 | 01:46 PM
redline2k's Avatar
Thanks.
Sorry no to Canada
Old May 29, 2006 | 06:04 PM
crb99ws6's Avatar
IS the pan in good shape? I'm interested
Old May 29, 2006 | 07:21 PM
ou812/z28's Avatar
i need the pan and starter do u still have it....how much to ship to hammond,la 70401
Old May 29, 2006 | 09:03 PM
Demon SS's Avatar
PM sent
Old May 29, 2006 | 09:06 PM
redline2k's Avatar
Yes the pan is good
Old May 29, 2006 | 09:11 PM
redline2k's Avatar
Pm's sent still have all parts
Old May 29, 2006 | 11:50 PM
redline2k's Avatar
Pm's replied to
Old May 30, 2006 | 06:52 AM
idf1966's Avatar
In case the other interest in the pan and pick up falls through, instead of the previously-mentioned Canadian address, I have one in NY, 13669.
Let me know.
Old May 30, 2006 | 08:57 AM
redline2k's Avatar
Updated. If it's still up there then I still have it.
Old May 31, 2006 | 12:09 AM
85ta383's Avatar
sent you a pm
Old May 31, 2006 | 03:25 PM
NassyVette's Avatar
PM sent, I need the front engine cover.
Old May 31, 2006 | 04:15 PM
redline2k's Avatar
cover pending, pan and pick up gone.
Old May 31, 2006 | 04:30 PM
redline2k's Avatar
All parts are first to pay, first to get them.
