Delphi/ Lucas 32#/hr injectors $230
Old Sep 5, 2006 | 10:32 PM
ZL1Killa's Avatar
Default Delphi/ Lucas 32#/hr injectors $200
these injectors have about 4k miles on them and have been kept in excellent condition. I know the offset table you need to use with them and I know what def and min injector pulse widths to use with them, and the IFR.
$200 ;will be shipping UPS
I will have pictures up soon, but these are the ones where you cannot use the retainers, which is fine still as they were fine on my car.
Part Number Delphi D17208A (Lucas old 5207009, Lucas New 621020)
Static Flow Rate @ 43.5PSI (300kPa) = 31.6 lb/hr = 332cc/min = 239g/m
Static Flow Rate @ 58.0PSI (400kPa) = 36.5 lb/hr = 384cc/min = 276g/m
Dynamic Flow Rate @ 43.5PSI (300kPa) = 6.68 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Dynamic Flow Rate @ 58.0PSI (400kPa) = 7.72 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 16.2 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Image quality has been reduced so image will fit on here. if you want good pictures pm me your email address
Attached Thumbnails Delphi/ Lucas 32#/hr injectors 0-injector.jpg
Old Sep 7, 2006 | 10:39 AM
ZL1Killa's Avatar
anyone?
Old Sep 11, 2006 | 09:05 PM
ZL1Killa's Avatar
36.5lb/hr injectors... i know someone has to be upgrading sometime
Old Sep 14, 2006 | 01:03 PM
ZL1Killa's Avatar
36.5 injectors
Old Sep 28, 2006 | 11:50 AM
ZL1Killa's Avatar
$200.... 36.5# injectors @ 58psi
Old Dec 2, 2006 | 12:14 PM
ZL1Killa's Avatar
needing to get rid of these suckers
$200 for the delphi 36.5# injectors
I also have the stock 28.8lb/hr injectors
Old Jan 8, 2007 | 07:13 AM
ZL1Killa's Avatar
guys.... anyone need em' $200 ?? I need to get rid of em
Old Jan 8, 2007 | 07:19 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I need some, but for around 150$.
Old Jan 9, 2007 | 01:26 AM
ZL1Killa's Avatar
could you deal with 160 shipped to wherever you are (meaning these things will be shipped to ya and you will recieve them in 3 days , and you will get tracking #
Old Jan 12, 2007 | 11:49 AM
ZL1Killa's Avatar
SOLD.... silly short message thing
