2001 Camaro SS Drag Chassis and More For Sale!!!
Sale is for my 2001 Camaro SS Rolling Chassis. The car has 58,000 miles on it with many of the parts of the rolling chassis not having that many miles as they have been replaced with upgraded parts as indicated. Items found under the “Potential Separate Sale” section will be considered for a separate sale and if done so price for the remainder of the rolling chassis will be adjusted accordingly. The center console pieces are currently not installed; however, I have all of these pieces in addition to the factory monsoon sound system etc. which will be included with the chassis, unless otherwise indicated as sold. Further, all electronics for the computer/pcm, speed sensors, etc. are in tact. The IAC motor plug has been extended and the TPS sensor pig tale has been removed for previous use with my 434 c5r sb2.2 intaked combination which has since been sold. Please pm, email at nfulford@hcea.com, or call (pm me for number) if you have any questions. Thanks. Also, can get pictures and have many pictures at the moment.
Potential Separate Sale Items (items are included in the rolling chassis, if separate sale desired make offer on respective item):
-Transking th400 with JW Ultrabell blow shield (already modified to fit with no clearance issues with the back cover bolts of an ls1), transbrake w/ reverse manual valve body. Transmission was purchased from HPE which receives their transmissions or did at the time from Transking. Transmission was backed in and out of my driveway with no other run time on it. Transmission was around 1500 new and I was told is good for 1500 or less horsepower.
-Fuddle Racing 4000 stall setup for 700n/a horsepower and 900 n20 horsepower with an emphasis toward n/a performance. Converter was around 700 new. (see transmission usage)
-TCI Flex Plate (bran new)
-Madman Trans Cooler kit with dip stick (bran new)
-Nasty Performance Fuel system with Weldon 600A pump, tank, all lines run, etc. (bran new)
-Random Technologies Torque Arm
-BMR Adjustable TH400 Cross Member (can adjust torque arm mount up or down for instant center adjustment) (bran new)
-Autometer Pro Comp dual range 9000 rpm tach with light (bran new)
-Autometer Pro Comp water temp gauge (2 5/8”) (bran new)
-Autometer Pro Comp oil temp gauge (2 5/8”) (bran new)
-Dr. Gas side exit (both exit on driver side before rear tire) oval 3.5” exhaust with h-pipe which is universal for different header combinations)
-custom terminator boxes with 3” magnaflow mufflers with dumps (many hours in this setup and has only seen idle time)
Items which must remain with the car:
-Performance Automotive Fabrications 10 Point Roll Cage certifiable for 8.50 or slower with dual swing outs (passenger and driver), removable window net, seat mount, etc. Cage is Mild Steel and powder coated. Absolute top notch work, through dash, and retains rear speakers.
-Jegs Seats with seat covers
-Performance Automotive Fabrications chrome molly seat brackets for seats
-Spohn adjustable Lower Control Arms with rod ends (never driven on)
-Moser 12 bolt rear with 4.56 gears, solid collar, spool, 33 spline axles, ½” wheel studs which match the lugnuts open ends near perfectly
-Billingsly Racing Sway bar welded on to rear end with rod ends etc (bran new).
-Strange single adjustable front drag shocks with 300 pound springs (bran new).
-Byunspeed adjustable on the car panhard rod (bran new)
-Bogart Bolted D10 wheels requiring no grinding of brake calipers with 26 x 4 Mickey Thompson sportsmans up front (a few thousand miles on them) and 315/60/15 Mickey Thompson ET Street Radials (30/13.50/15) on the back bran new.
-4” Glasstek pin on cowl hood un finished
-B&M Pro Ratchet Shifter installed (bran new)
Car is the pewter color.
Looking to get $10,000 for all together; however, prices will be adjusted if individual items are sold. Also, I’m sure I’m missing a few things here and there so feel free to inquire about specific questions. Thanks again.
Have car on trailer at the moment and can meet or drop off at house if serious. Long trips are negotiable and will be arranged if necessary.
Nick
Nick
Thanks for the interest all, responding or have responded to your pm's. One thing I forgot to add is there are subframe connectors on this car which were originally slp connectors but they have since been modified and are welded in multiple locations to the car.
I've also added some pictures to my photobucket page as well. The one picture of the cage with the window net is prior to the final mounting of the seats. Obviously some of these pics the front is very raised as there was not motor in it at the time. Feel free to ask away on any questions or if need be request any pictures. At this time these are the only pics I have that you can see (have some others saved on my computer but they did not turn out well focus wise or are too dark). Thanks.
Ok, i've now added many pictures of the underneath of the car as well as the interior. I've also included a small description caption on each picture. All of this can be found in the photobucket link in my signature. Enjoy!
Forgot to add that the car comes with a car cover from California Car Covers, which is why you'll notice many of the pictures of the interior have it on.
Nick
Nick
Car is sold. Look for new thread on fuel system and transmission/torque converter/flexplate as these items are left. Guy who bought the car is dropping in a 106mm fed 449 SBC, pretty cool!
Originally Posted by DAPSUPRSLO
Yes, finishing up details of sale at the moment to wickedred!
