P&P TB.. Is It Worth It?
Is it really worth it to have the TB P&P??? What kinda gains are we talking about here? With my mods (see sig) can i benfeit from a P&P TB??
Yeah its worth it. Just get a ported and polished stocker, theyre pretty cheap to get. Maybe a gain of around 5 HP, not much but it helps out, especially once you mod more.
Totally worth it. Minimal effort and pure performance. Some people are claiming/showing up to 10rwhp with it. Depending on mod depth and can be a great finishing touch or a starting block.
i was thinking of sending out my stocker to Bo White and have him P&P the TB..
couple other questions..
1) how do you take the TB off?
2) will i need new gaskets?
my buddy P&P his TB aobut 2 yrs ago and after that every time he was at WOT, nothing but black smoke out the tail pipes..
i do not want that. Will i get that with this mod? What did he do wrong?
and yes the bump stop mod is done already..
thanks
thanks
Disconnect the MAF and hose to the lid, take the lid and MAF and bellow off, take the hoses going to the bottom of the TB off- will be a small amount of coolant come out but no worries, take the vacuum line off thats on the pass. side of the TB, disconnect the IAC and TPS on the driverside of the TB, take the three bolts out of the TB- 1 up top and 2 on the bottom....its off. When ya put it back on just reverse the procedure.
you forgot that when i am done taking the TB off, you were suppossed to say send it to me
if you recall we talked about 2 months ago.. you were going to P&P my TB... not another one my stock one! Trending Topics
Originally Posted by Magnet
definately a worthwhile mod!! especially if you elarn to do it yourself..its free and feels good to do work on your own car!!
damn metal shaving gettin all stuck in my fingers
I just used a drill with some sanding drums to get the big stuff, then worked my way up to 1000 grit sand paper(wet sanding past 400 grit) and some mothers mag and alum polish. Took a full day. I say do it yourself.
Originally Posted by FireSilverLullaby
Yeah its definitley worth it, and just do it yourself. But dont fill in those ports with jbweld, cause someone got theirs sucked into their intake.
So?
