Clutch Line conversion Fitting solved!
Old Nov 10, 2006 | 11:33 AM
Elec87's Avatar
Default Clutch Line conversion Fitting solved!
I have been on a quest to convert my clutch line over to my s-10 Clutch master and have come up with some quick connect fittings that allow me to use -4 lines and ditch that quick disconnect.
This fitting Will install in the place of the stock style fitting and uses the stock roll pin. This can be used in almost all late model gm clutch masters and slaves. You can remove the stock f-body fitting from the throw out bearing or from the slave and install this..... these are kind of expensive but being able to convert the stock slave to a -4 style fitting is well worth the cost.
I snapped a few pics and can get you guys some part numbers If you want.
Old Nov 10, 2006 | 11:35 AM
67RSCamaroVette's Avatar
-3 and -4 teflon fittings ARE expensive..
$20 ea i'm guessing?
please post the part numbers, photos, etc on the FAQ's, there will be lots of people to thank you.
Old Nov 10, 2006 | 12:08 PM
Elec87's Avatar
I will do that!
45 each OUCH!
Old Nov 10, 2006 | 12:12 PM
can you say, lathe project?
what a rip off.. that part takes less than a minute in a CNC lathe to make.
Old Nov 10, 2006 | 12:29 PM
MrDude_1's Avatar
Elec87:
its VERY COOL that you found these... thanks for sharing!
while i totally agree with you 100%, i have yet to find someone that makes them.
what i need is one for the slave that has the fitting sticking out far enough that its at teh bellhousing level.
then i can stick a -4an banjo on my master cyl and connect the two with braided line...
if you have the hookup with a CNC lathe to do this, i'll pay ya the same "ripoff price" as above.
Old Nov 10, 2006 | 01:51 PM
MrDude_1's Avatar
hey man... heres some for $19.20!!! http://www.novak-adapt.com/catalog/kit_hcr3.htm
not direct to AN, but its a start...
im going to keep looking....
btw, i learned that some Jeeps use the same fittings as GM does... thats the breakthru thats letting me find more adapters!
jeep guys love DIY stuff, and that really helps
mods:
absolutely no advertiser carries anything like this, so it shouldnt be a issue for us to post it.. right?
Old Nov 10, 2006 | 03:37 PM
Elec87's Avatar
If they say it is okay I will list it all, the jeep units are actually a tad smaller than these they work but have some play (movment). These are specific for the gm applications.
Elec
Old Nov 10, 2006 | 03:55 PM
MrDude_1's Avatar
Elec
no need to wait.. list em all..
do they have one thats long enough that the AN fitting is clear of the bellhousing?
Old Nov 10, 2006 | 04:23 PM
Elec87's Avatar
They are not that long but you can run the braided line in and secure it before installing the transmission.
The part numbers are:
Mcleod
139027 -4 90 degree
139026 -4 straight
I bought them from www.Carshopinc.com.....
Old Nov 10, 2006 | 07:57 PM
if anyone wants to make one in SolidWorks, i can have some made and sell them at cost. i've got a buddy with a CNC shop but my laptop's down for the count as of right now, so I cant draw them up myself. what exactly are you looking for? wouldnt the o-ring/roll pin to -4male be easiest?
Old Nov 21, 2006 | 02:25 PM
MrDude_1's Avatar
has anyone found anything new on this?
i really HATE to spend this much on the adapters, but i really want to replace my quick connect and stock line with straight -4an...
Old Dec 1, 2006 | 09:41 AM
MrDude_1's Avatar
i havent given up yet.
how about 17.99 for TWO!
thats right, i was looking around, and i came across russell part number 640281.....
Attached Thumbnails Clutch Line conversion Fitting solved!-russle-clutch-fitting.jpg   Clutch Line conversion Fitting solved!-summit-pricing.jpg
Old Dec 1, 2006 | 05:16 PM
that's only -3 though...
Old Dec 4, 2006 | 07:30 AM
MrDude_1's Avatar
yea, but -3 is still very overkill for the fluid volume required... trust me, there will be no restriction.. lol
Old Dec 4, 2006 | 10:36 AM
Shu's Avatar
Shu
great find guys! I'm thinkin this will be my next mod.
Old Dec 15, 2006 | 10:42 AM
MrDude_1's Avatar
bump for more views....
Old Dec 16, 2006 | 01:13 PM
NSTY WS6's Avatar
What is the advantage of going with the -3/-4an line over the stock? If it is anything other than it being a conversion and some needing a longer/shorter line from the master to the slave?
Old Dec 16, 2006 | 03:36 PM
the stock line has a pretty bad restriction in the first couple inches, and AN teflon line will flow better and is higher quality (more flow without pressure drop = quicker action)
Old Dec 17, 2006 | 06:09 PM
Project GatTagO's Avatar
Nice find! The -3 line is plenty big.
Andrew
Old Dec 18, 2006 | 08:38 AM
MrDude_1's Avatar
Andrew
oh yea... its bigger then the 1/8th guys drill it out to.. and its bigger then the hole in the clutch fittings..
im going to do a full writeup when i install mine... but here are some pics...
Attached Thumbnails Clutch Line conversion Fitting solved!-box1.jpg   Clutch Line conversion Fitting solved!-box1b.jpg   Clutch Line conversion Fitting solved!-compare1.jpg   Clutch Line conversion Fitting solved!-compare2.jpg   Clutch Line conversion Fitting solved!-size1a.jpg
Clutch Line conversion Fitting solved!-size1b.jpg   Clutch Line conversion Fitting solved!-size1c.jpg   Clutch Line conversion Fitting solved!-boxpartnumber.jpg
