Clutch Line conversion Fitting solved!
Old Nov 21, 2011 | 07:15 AM
  #61
battery1882's Avatar
Originally Posted by shifty`
Yes. One is intended to replace your master cylinder fitting, the other is intended to replace your slave cylinder fitting.
As I understand it, either the fitting(s) or the tension pins are different - as in you can only put one of each in their respective locations.
It looks like Summit has them back in stock, too.
is this true?
I got this thread going -> https://ls1tech.com/forums/manual-tr...tch-pedal.html
basically rock hard pedal and slave won't push clutch pp enough.
I'm hoping I put the wrong fitting on there. I will go check this tommorow
wish me luck guys..
Old Nov 23, 2011 | 03:08 AM
  #62
Jeff Smith's Avatar
Good Inform..Sub.
Old Nov 23, 2011 | 04:17 PM
  #63
Kory 88Iroc Lt1's Avatar
Great info, just when I needed it.
Thanks,
Kory
