Camaro install pics
Pioneer HU he already had
Infinity 611a monoblock
Infinity 7541a 4channel
2x Infinity Kappa Coaxials
2x Elemental Designs SQ10's
Knukonceptz Wiring
Oznium Cold Cathodes and Switches
Custom DrivenAudio sub box/amp rack
The ride
The radio
Speaker installed in front doors (all new wire was ran to the amp)
Speaker installed in sail panel, the tweeter is so deep on these speakers it hits the grill but we were able to get them back on
The 4 channel is underneath, with the monoblock on top with some cold cathode tubes mounted underneath it for some bling bling
The view. It turned out looking absolutely bad ***, ill get some pics from nite soon.
We also put cathodes under the dash, unfotunately I sat on one of them and it cracked so there isnt one on the drivers side but hopefully there will be a replacement installed soon. We also put switches in the center counsle for the rear lighting, under dash lighting, and the power antenna which I wired up for Paar. All and all the system sounds great and looks even sweeter. Questions, comments, etc
another question I have the JL speakers and they are oval...is there some type of bracket I need to get for them to fit in the sail panels?
according to the sound advice guy they are the right size speakers for the car.
Chad
Chad
Other than that, not a bad looking install. Could use some dark tint, yes, and make sure you have an alarm system.
Im sure if the well enclosures could be made to point up into the window more they would hit even crazier
Shrugs Ill also chime in and say I love my 13Ov2 in my ttop box from subthump
Those 12s are crazy they are MUCH better than the old Full well enclosure 15;s box i had with rockford fosgate 15's HE-2.
Id feel safe going with eD!
before this I had never heard of them.
And what the hell are you defending? I didn't bash ED, I said you picked the wrong sub for your install. Instead of trying to give us some BS credentials to defend yourself, try reading my post. And try doing a little research beforehand next time you buy your equipment.
Sometimes you spend money on a reputable and supoposedly far superior item cause all the tests show it.. and then when you put it in.. and such it sucks... and doesnt live up to your expectations.
Sometimes you get a gem like these damn eD subs which I lucked out on, and they turn out to blow away your expectations.
Tests or no tests specs or no specs.. its the results of having happy customers which keep peopel and companies in business
So easy trigger.. lay off the guy and dont get all flamey
I know you are tryign to inform people about what you think and can prove are superioir subs etc,... but you do so sometimes in such an abrasive fashion you comepletely fail..
just my teenie tiny observation chief... no harm no foul
You ALWAYS have to match speakers to boxes, whether you buy ED or a better brand. If you think otherwise, then stick to Dual subs from Wal-mart.
If you guys didn't understand that, ask instead of giving me "blah blah blah I've installed 20 setups before blah blah blah"
As far as customers, most people think BOSE is great. Enough said about that.
or am i retarded as usual
No matter how little depth you had, the SQ10 was the wrong sub. Period. If you can't fit the other ED subs of that size in there, switch brands or switch boxes.
You just installed a couple of oversized woofers. Nothing "sub" about them.
I have barely a ducktape's knowledge about the stuff
Do you like the 13Ov2's? Just curious to compare your thoughts to what im experiencing with them. Havent ever worked with the SQ10 so cant say anythign about them specifically.
Only thing I dont like about the set up is how blatantly you advertise you have a system and it just begs for some dude to smahs the window and try to take it.
Do you have anything bolting it down liek thru those sail panels? You cant very well drill intot he gas tank
