4th gen 10 bolt w/ goodies
98 10 bolt out of a trans am
3 channel
* new richmond 3.73 gears ( less then 2k )
* new moser axels w/ new studs ( less then 2 k )
* auburn posi
* new cover bolts
was professionally rebuilt and has less then 3000 miles on it since new seals and bearings ect...., was taken out only for an upgrade for a 12 bolt in a buddy of mines car. it has no calipers or backing plates since they were used in the swap.the only reason i am not using this rear is because it is 3 channel and not 4 channel. i want to retain my traction control.
PICKUP ONLY! MEMPHIS TENNESSEE!
450$
i have a brand new in the box ta performance cover that i was going to put on there i will add to the sale for 160$ which is what i paid for it. will not sell seperate from rear end or ill just use it in my camaro
rear end alone 450
w/ new! cover 610
3 channel
* auburn posi
* new cover bolts
450$
rear end alone 450
w/ new! cover 610
very lil noisy even for a richmond gear i was told ( which are known to be noisy b/c they are cut soooo tight )
in his car w/ his exhaust he said you couldnt hear it at all.
i never personally rode in his car when it was installed
i known him from my local f body club for quite awhile and know the local shop that built and installed the rear very reputable local memphis shop
if interested and want to come look at it im here at the shop m - f from 9 - 5 sometimes a lil earlier or later but always there at those times.
the housing itself has @ 60k
everything else has been replaced at one time w/ new parts
the auburn was bought used w/ 20k and less then 2k since then so a lil less then 22k on the posi
everything else has less then 2k miles
bump for a good buy...
