1994 lt1 part out lots of stuff!!!!
all parts are obd1, selling because i am through building and dumping money into this project. all offers will be considered, no trades!! i do not want anymore parts!!! After i have sold all the parts i will be selling the car as a roller with the bottom end still in the car.
monster transmission 4l60e good for 500rwhp.......1200
heads, with new 3 angle valve job and comps 987 springs....450
lt1 intake, ported for a 58mm, runners smoothed painted red...150
58 mm throttle body from summit....200
accel 30 lb injectors....200
gmpp 1.6 roller rockers.......150
long tube headers, pacesetters ceramic coated....400
x pipe......50
cross drilled and slotted rotors 4way.......100
stock module and coil 40k....20
reman water pump........50
optispark non vented 10k.......100
1le ac delete pulley.....50
comp cam 466 218/224 570/565...200
comp cams stock lifters.......45
torq thrust II's 17X9's with MT's in the rear......set for 1200
in tank fuel pump 255lph granatelli.............100
adjustable fuel pressure regulator.........130
everything is pretty much new, only started the car a few times. excepted if stated with miles, all reasonable offers considered. pictures upon request email address paulmaro13@yahoo.com
need all of this gone before oct 31st!!!!!!!!!!!!!!
x pipe......50
