Parting out built 98 TA H/C car
I have lost all interest in the TA. I have two other cars I want to work on.
bare short block 346
The shortblock was freshened up 35K ago (leak down performed when taken out..... no worse than 4% on any cylinder)
--stock crank, rods, pistons
--GM rings
--Clevite 77 Main and Rod bearings
--ARP rod bolts
--Pistons are flycut to .040 (baby flycuts) 725.00
Cam
M2 (228/234 .607/.598 110 +2) 10K on it $225.00
in stock shortblock H/C has made 457/415 and ran 10.80's with 6speed in a 3300 lb car
-Yank trans TH400 trans/torque arm mount $140.00
-BMR adjustable torque arm black (not moly) include some simple parts I made to allow use with Moser 12 bolt with no bolt issues $220.00
-Drive Shaft King custom shaft Moser 12 bolt to TH400 $175.00
-Spohn Pro Drag sway bar black (just ordered the body brackets from Spohn so will now be complete) was brand new and went to the track twice $290.00
-7.350 trick flow pushrods (just replaced new apox 100 miles) $60.00
- modified stock shifter for RVB TH350/400 (works slick and locks out 3rd unless you hit the button) $70.00
Remaining roller 98TA body was M6 from factory Mystic teal over all nice but clear peeling on the back bumper and paint cracked on the lower front bumper and a spot on the hood what a car part fell on it. Not gutted. Only real weight reduction front sway bar and bumper support weighs 3600 with 210lb driver. Clear title will come with some SS 10 spoke that the chrome is not very good on. $3300.00
I will ship and accept PayPal you pay 3% fee and any freight charges.
Serious inquiries call Richard 214-793-0029
--GM rings
--ARP rod bolts
Cam
From: sneaking in your back door as you leave!/cartersville ga
heres the info on the exhaust and headers,
-over the axle true duals with Dr Gas X and magnflow mufflers with Jethot
long tube headers (the way its designed needs to all go together as a set)
will not ship $550.00
its all in the add, it just ran together. i didnt see it the first time neither
fixed it sorry about that
you have any better pics of the Yank trans TH400 trans/torque arm mount,send to nunoacosta@yahoo.com please
